Hi!
I update from 1.34.26 to v1.36.12 but now are the Videos are blurred.
How can I fix that?
Thanks in advanced
[SOLVED] Blurred Video after update
- biologisch
- Bildschirmfoto von 2022-01-15 16-47-00.png (228.92 KiB) Viewed 3178 times
- Bildschirmfoto von 2022-01-15 16-47-23.png (127.16 KiB) Viewed 3178 times
ZM Versions = 1.36.33
zmeventnotification Version = "6.1.28"
Re: Blurred Video after update
Are you using Ffmpeg?
- biologisch
Yes, Im using ffmpeg.
- biologisch
It seems to be an network issue. After rebooting the router zoneminder stores the videos normaly.
