Change function of camera when changing SmartThings location mode
swolsen
Post by swolsen » Thu Apr 29, 2021 10:51 am
Not sure if anyone is interested in this but I wrote a PHP CLI script to update certain (inside) monitors to change from [Monitor] to [Modect] and back depending on Smarthings location mode changing between [Home] and [Away]. I run it under a cron job every 5 minutes.
#!/usr/bin/php
<?php
	Uses curl to get Smartthing's location mode (away or home) and set specified zoneminder camera id's function
	(Monitor or Modect)	based on ST mode. Requires personal authorization token (PAT) from your Smarthings account
	https://account.smartthings.com/tokens
	Scott W. Olsen
	2021-04-28
$Monitors = array("1", "3"); // Zoneminder monitor id's for monitor function to set
$ZM_Host = "https://ZONEMINDERHOST"; // Zoneminder's host url
$ZM_Login = "user=USER&pass=PASSWORD"; // Zoneminder's login info
$ST_LocationID = "XXXXXXXX-XXXX-XXXX-XXXX-XXXXXXXXXXXX"; // your SmartThings Location ID
$ST_PAT = "XXXXXXXX-XXXX-XXXX-XXXX-XXXXXXXXXXXX"; // Your SmartThings personal access token
writelog("Initiating check for monitor id's : " . implode(", ", $Monitors));
$LocationMode = NULL;
$ch = curl_init();
curl_setopt($ch, CURLOPT_URL, "https://api.smartthings.com/v1/locations/$ST_LocationID/modes/current");
$header = array("Authorization: Bearer $ST_PAT");
curl_setopt($ch, CURLOPT_POST, false);
curl_setopt($ch, CURLOPT_HTTPHEADER, $header);
curl_setopt($ch, CURLOPT_RETURNTRANSFER, true);
curl_setopt($ch, CURLOPT_VERBOSE, false);
$result = curl_exec($ch);
if($result != false) {
	$obj = json_decode($result);
	//echo "\nbegin output\n$result\nend output\n";
	//displayObject($obj);
	$LocationMode = $obj->name;
	writelog("SmartThings Location mode = $LocationMode");
else writelog("No Results from ST");
if(!is_null($LocationMode)) {
	// get API Key from Zoneminder.
	curl_setopt($ch, CURLOPT_URL, "$ZM_Host/zm/api/host/login.json");
	curl_setopt($ch, CURLOPT_SSL_VERIFYPEER, 0); // Used to accept self signed SSL cert if using SSL
	curl_setopt($ch, CURLOPT_POST, true);
	curl_setopt($ch, CURLOPT_POSTFIELDS, $ZM_Login);
	curl_setopt($ch, CURLOPT_VERBOSE, false); // Set to true to see output of curl data when communicating with host.
		$API_key = json_decode($result);
		//displayObject($API_key);
		foreach($Monitors as $id) {
			curl_setopt($ch, CURLOPT_URL, "$ZM_Host/zm/api/monitors/$id.json?token=$API_key->access_token");
			$mobj = json_decode($result); // need error checking here.
			//displayObject($mobj);
			//print $result;
			$MonitorFunction = $mobj->monitor->Monitor->Function;
			writelog("Zoneminder Monitor $id function = [$MonitorFunction]");
			$setMF = false;
			if($LocationMode == "Home" && $MonitorFunction != "Monitor") {
					$MonitorFunction = "Monitor";
					$setMF = true;
			elseif($LocationMode == "Away" && $MonitorFunction != "Modect") {
					$MonitorFunction = "Modect";
					$setMF = true;
			if($setMF) {
				writelog("Setting monitor $id function to [$MonitorFunction]");
				curl_setopt($ch, CURLOPT_POSTFIELDS, "Monitor[Function]=$MonitorFunction&Monitor[Enabled]=1");
				writelog($result);
	else writelog('Curl error: ' . curl_error($ch));
curl_close($ch);
function writelog($w) {
	$file = fopen("/var/log/zm-setMonitorFunction.log", 'a');
	fwrite($file, date("Y-m-d H:i:s") . " $w\n");
	fclose($file);
// testing purposes
function displayObject($a) {
	foreach($a as $k => $v) {
			echo "[$k] => ";
			if(is_array($v) || is_object($v)) {
				echo "\n";
				displayObject($v);
			else echo "$v\n";
Users browsing this forum: No registered users and 8 guests
