Wansview w4 cloud cam
Brushpopper
Post by Brushpopper » Wed Mar 25, 2020 2:00 pm
I have several Wansview cameras and they are running great in ZM, but I just bought a 2 camera deal that is the new W4 "cloud" camera... I cannot set a static IP, there is not a username password for each, in fact I had to download the separate Wansview Cloud App, to get them up and running..
Anyway I have tried every RTSP combo, tried doing an Onvif probe, etc.. but cannot seem to get a picture up on my Montage.
Anyone else successful with one of these cams or have any idea what I need to input
TomW
Re: Wansview w4 cloud cam
Post by TomW » Thu Oct 15, 2020 3:26 am
Hi
I see this post goes back to March, 2020, but, I've just bought 2 of these IPCams on Prime day, and, I was planning to use ZoneMinder as my Linux based software. Since there was no replies, either from a forum member or the OP, I'm assuming there is a problem with these Cams. If that's the case, can someone confirm? I was willing to experiment with ZoneMinder to get them working, but, if the consensus is that they're too problematic, then please let me know, before I unbox them.
I was in too much of a hurry buying them, usually I do much more investigating before I make a purchase, but, it was Prime day, and I only had a limited time before the deal was over. Amazon makes returns easy, so, I'd rather return them and look at your compatibility list, and, find a better candidate.
Thanks in Advance
Tom
tommisgr
Post by tommisgr » Thu Oct 15, 2020 2:43 pm
from https://www.ispyconnect.com/man.aspx?n=Wansview
the link seems to be rtsp://IPadress/live/ch0 & rtsp://IPadress/live/ch1
try doing a test with vlc 1st
drhiii
Post by drhiii » Tue Dec 29, 2020 9:58 am
Anyone ever get a wansview w4 to work with Zoneminder? The suggested rtsp line did not work, sigh.
bitcrusher
Post by bitcrusher » Tue Feb 09, 2021 4:16 pm
Here's what worked for me with a Wansview W4 after lots of trial and error:
Source Type = Ffmpeg
Source Path = rtsp://Username:Password@IPofCamera:554/live/ch0
(where 554 is your rtsp port of course)
Method = TCP
You can configure rtsp quite effectively in the Wansview app on your mobile device - head to 'Local application' - and even set a different port. I am using 555 but had to reboot the camera before it seemed to come up on that port.
JanKowalik
Post by JanKowalik » Sun Mar 14, 2021 3:50 pm
jeffreytk421
Post by jeffreytk421 » Sun May 02, 2021 4:35 am
I got this to work on my new W4 just now. You will have to install the phone app and make an account. The app needs at least storage permissions to function.
On the phone app, add the camera it, then visit Settings > Local application.
Visit the "Local account" option.
Set the username and password here. Seems each camera gets an initial random username/password.
Visit the RTSP option.
See the FHD and SD URLs they give, which includes your username/password.
Optionally change the RTSP port you want to use.
I set two cameras up via Ethernet. Will change them to WiFi when I go to install them permanently. They had firmware updates which I did. One camera was a little touchy setting it up and took a few tries resetting it by holding the reset button 15 seconds (docs say just hold it until amber status light starting rapidly flashing) and going through the add steps a few times, but it finally worked.
I am getting about 16 FPS while connected to Ethernet.
Users browsing this forum: No registered users and 6 guests
