Alarm via API returns wrong value
tranzmatt
Post by tranzmatt »
I'm working with pyzm, but I think this applies to ZM itself.
When I send the arm() command, which posts:
[DEBUG 1] make_request called with url=http://192.168.1.247/zm/api/monitors/alarm/id:3/command:on.json payload={} type=get query={}
Where mid=3. I get a return json of something like
ARM: {'status': 'Alarmed event id: 2'}
But in the web-ui, ID #3 seems to have been created instead.
Can anyone explain the discrepancy? Shouldn't "3" be returned in the json string? I've tested multiple times.
asker
Re: Alarm via API returns wrong value
Post by asker »
This seems to be a zmu bug. If you run sudo -u www-data zmu -m<mid> -a -U admin -P <password> you'll see it returns a wrong eid. May want to log it in ZM GH repo - but I think this is a known issue. Needs to be solved, either way.
Please read before posting:
ES docs
zmNinja docs
tranzmatt
Post by tranzmatt »
Ok, I've submitted a ticket to the github repo.
