zmNinja Mass Delete
neepninja
zmNinja Mass Delete
Post by neepninja »
Hello. Is there a way to mass delete all events in ZM using the zmNinja app on android? At the moment the only way I can find is to go into events list and click on the circle with minus and delete one by one. Not ideal but gets the job done but when yo uhave over 50 events this process becomes time consuming. Yes I could go into zm and select all and delete all but on the go the app would be ideal.
Thanks.
asker
Re: zmNinja Mass Delete
Post by asker »
(Moving this post to the mobile forum)
No, there isn't. A big reason for that is because there are no bulk delete APIs. The APIs only allow deletion on a per event basis.
So even if there was a UI option, it would result in calling a single API for a single event and keep looping it, which would be a poor experience compared to bulk deletion in the ZM web console which directly hits the DB.
Please read before posting:
ES docs
zmNinja docs
