I have some problem running zoneminder v1.30.0 on my pi3 (this is the only thing I'm running on the pi)
the zonmidner server have only 1 ip camera , and after 3-4 movment recording it get stuck (and even when It recoreding , the image get stuck a lot - I don't get smooth captured video )
when I see the image live from the pi - I don't have this problem - so it's not a wireless problem (at least I think).
when I entet zonminder logs I see:
do service zoneminder status
● zoneminder.service - ZoneMinder CCTV recording and surveillance system
Loaded: loaded (/lib/systemd/system/zoneminder.service; enabled; vendor prese
Active: failed (Result: exit-code) since Wed 2020-05-27 18:50:08 IDT; 3 days
Process: 9047 ExecStop=/usr/bin/zmpkg.pl stop (code=exited, status=1/FAILURE)
Process: 7547 ExecStart=/usr/bin/zmpkg.pl start (code=exited, status=0/SUCCESS
Main PID: 7576 (code=exited, status=4)
May 27 18:50:07 raspberrypi sudo[9053]: root : TTY=unknown ; PWD=/usr/share/
May 27 18:50:07 raspberrypi sudo[9053]: pam_unix(sudo:session): session opened f
May 27 18:50:07 raspberrypi sudo[9053]: pam_unix(sudo:session): session closed f
May 27 18:50:07 raspberrypi sudo[9061]: root : TTY=unknown ; PWD=/usr/share/
May 27 18:50:07 raspberrypi sudo[9061]: pam_unix(sudo:session): session opened f
May 27 18:50:08 raspberrypi sudo[9061]: pam_unix(sudo:session): session closed f
May 27 18:50:08 raspberrypi systemd[1]: zoneminder.service: Control process exit
May 27 18:50:08 raspberrypi zmc_m2[8703]: INF [Got signal 15 (Terminated), exiti
May 27 18:50:08 raspberrypi systemd[1]: zoneminder.service: Unit entered failed
May 27 18:50:08 raspberrypi systemd[1]: zoneminder.service: Failed with result '
and saw this (arround the time the service has stop)
ay 27 18:50:01 raspberrypi zmc_m2[8703]: WAR [Last image read from shared memory 14 seconds ago, zma may ha$
May 27 18:50:02 raspberrypi zmdc[7576]: WAR ['zma -m 2' has not stopped at 20/05/27 18:50:02. Sending KILL t$
May 27 18:50:02 raspberrypi zmdc[7576]: INF ['zma -m 2' exited normally]
May 27 18:50:06 raspberrypi zmc_m2[8703]: INF [Door: 87000 - Capturing at 20.83 fps]
May 27 18:50:07 raspberrypi zmpkg[9047]: INF [Sanity checking States table...]
May 27 18:50:07 raspberrypi zmpkg[9047]: INF [Command: stop]
May 27 18:50:08 raspberrypi zmc_m2[8703]: INF [Got signal 15 (Terminated), exiting]
May 27 23:09:03 raspberrypi kernel: [513027.215560] rpi_firmware_get_throttled: 1 callbacks suppressed
May 27 23:09:07 raspberrypi kernel: [513031.376407] rpi_firmware_get_throttled: 1 callbacks suppressed
May 27 23:09:07 raspberrypi kernel: [513031.376415] Voltage normalised (0x00000000)
May 28 05:09:08 raspberrypi kernel: [534632.135576] Voltage normalised (0x00000000)
May 28 06:09:08 raspberrypi kernel: [538232.601304] Voltage normalised (0x00000000)
May 31 12:09:02 raspberrypi kernel: [819025.923383] Under-voltage detected! (0x00050005)
May 31 12:09:08 raspberrypi kernel: [819032.163370] Voltage normalised (0x00000000)
maybe something happand to my power suplly , and this is why I'm getting all this errors?
and this is the reason zonminder stop working ?
Thanks,
