Hello, I am new to this and I have installed version 1.34.2 on Ubuntu Desktop 18.04.
I am just messing around a little with adding a Wyze Cam with the beta firmware of RTSP, but when I use H264 Passthrough to record audio 24/7. It doesn't record the correct length of segments. I am not sure why it doesn't work. Please help!
Wyze Cam not recording correct length segment
Re: Wyze Cam not recording correct length segment
What is the correct length? Are the resulting files playable? How about turning on debug and checking the logs?
The correct length is 10 minutes and the files that are made are playable. I will have to figure out how to turn on debugging and where to get the logs.
So there is a setting under Options -> Config... EVENT_CLOSE_MODE... if it is something other than time you can get shorter events
Ok, it is set to idle but the logs are saying multiple things like:
Got empty memory map file size 0, is the zmc process for this monitor running?
and
'zma -m 2' exited abnormally, exit status 255
and
After I set the EVENT_CLOSE_MODE to time it is working for now.
It was working all night until this morning and it gives me these errors in the log:
Can't find process with command of 'zma -m 2'
Last analyse time for 2 Monitor-2 was zero.
Restarting capture daemon for Monitor-2, time since last capture 53 seconds (1581692146-1581692093)
And a couple times before the errors it would make a 5 minute video and then a 15 minute but it should be 10 minutes. This doesn't matter as much as the 1 minute videos though.
2020-02-14 08:59:41.753619 zmc_m2[8713].INF-zm_ffmpeg.cpp/70 [Queue input is backward in time]
2020-02-14 08:59:41.613050 zmc_m2[8713].INF-zm_ffmpeg_camera.cpp/889 [Event video offset is -0.131 sec (<0 means video starts early)]
2020-02-14 08:59:41.551377 zmc_m2[8713].INF-zm_videostore.cpp/62 [Opening video storage stream /var/cache/zoneminder/events/2/2020-02-14/770/770-video.mp4 format: mp4]
2020-02-14 08:59:41.537961 zma_m2[8716].INF-zm_monitor.cpp/1522 [Monitor-2: 001 - Opening new event 770, section start]
2020-02-14 08:59:41.316740 zma_m2[8716].INF-zma.cpp/136 [In mode 4/1, warming up]
2020-02-14 08:59:41.310868 zmc_m2[8713].INF-zm_monitor.cpp/2546 [Monitor-2: images:1 - Capturing at 0.50 fps, capturing bandwidth 45045bytes/sec]
2020-02-14 08:59:41.253074 zmc_m2[8713].WAR-zm_ffmpeg_camera.cpp/658 [Monitor dimensions are 640x480 but camera is sending 1920x1080]
2020-02-14 08:59:39.313713 zmc_m2[8713].INF-zm_ffmpeg_camera.cpp/201 [Priming capture from rtsp://admin:password@192.168.1.8/live]
2020-02-14 08:59:39.244781 zmc_m2[8713].INF-zmc.cpp/223 [Starting Capture version 1.34.2]
2020-02-14 08:59:39.227220 zmdc[8716].INF-zmdc.pl ['zma -m 2' started at 20/02/14 08:59:39]
2020-02-14 08:59:39.227210 zmdc[1107].INF-zmdc.pl ['zma -m 2' starting at 20/02/14 08:59:39, pid = 8716]
2020-02-14 08:59:39.194427 zmc_m2[8713].INF-zm_ffmpeg.cpp/82 [Enabling ffmpeg logs, as LOG_DEBUG+LOG_FFMPEG are enabled in options]
2020-02-14 08:59:39.077660 zmdc[8713].INF-zmdc.pl ['zmc -m 2' started at 20/02/14 08:59:39]
2020-02-14 08:59:39.077660 zmdc[1107].INF-zmdc.pl ['zmc -m 2' starting at 20/02/14 08:59:39, pid = 8713]
2020-02-14 08:59:39.038880 zmdc[1107].INF-zmdc.pl [Command 'zmc -m 2' removed from pending list at 20/02/14 08:59:39]
2020-02-14 08:59:38.978620 zmdc[1107].INF-zmdc.pl ['zma -m 2' exited, signal 14]
2020-02-14 08:59:38.941750 zmdc[1107].INF-zmdc.pl ['zma -m 2' sending stop to pid 8708 at 20/02/14 08:59:38]
2020-02-14 08:59:38.849290 zmwatch[1321].WAR-zmwatch.pl [Restarting capture daemon for Monitor-2, no image since startup. Startup time was 0 - now 1581692378 > 45]
2020-02-14 08:59:28.806670 zmwatch[1321].WAR-zmwatch.pl [no memkey in zmMemInvalidate]
2020-02-14 08:59:28.764640 zmdc[8708].INF-zmdc.pl ['zma -m 2' started at 20/02/14 08:59:28]
2020-02-14 08:59:28.764640 zmdc[1107].INF-zmdc.pl ['zma -m 2' starting at 20/02/14 08:59:28, pid = 8708]
2020-02-14 08:59:28.692550 zmdc[1107].INF-zmdc.pl ['zmc -m 2' exited, signal 14]
2020-02-14 08:59:28.678087 zmc_m2[8701].INF-zmc.cpp/223 [Starting Capture version 1.34.2]
2020-02-14 08:59:28.517790 zmdc[1107].INF-zmdc.pl ['zmc -m 2' sending stop to pid 8701 at 20/02/14 08:59:28]
2020-02-14 08:59:28.246169 zmc_m2[8701].INF-zm_ffmpeg.cpp/82 [Enabling ffmpeg logs, as LOG_DEBUG+LOG_FFMPEG are enabled in options]
2020-02-14 08:59:28.198650 zmdc[1107].WAR-zmdc.pl [Can't find process with command of 'zma -m 2']
2020-02-14 08:59:28.099930 zmdc[8701].INF-zmdc.pl ['zmc -m 2' started at 20/02/14 08:59:28]
2020-02-14 08:59:28.099910 zmdc[1107].INF-zmdc.pl ['zmc -m 2' starting at 20/02/14 08:59:28, pid = 8701]
2020-02-14 08:59:28.053810 zmwatch[1321].INF-zmwatch.pl [Restarting capture daemon for Monitor-2, shared data not valid]
2020-02-14 08:59:28.030910 zmdc[1107].INF-zmdc.pl [Starting pending process, zmc -m 2]
2020-02-14 08:59:28.008390 zmwatch[1321].ERR-zmwatch.pl [Memory map file '/dev/shm/zm.mmap.2' does not exist. zmc might not be running.]
2020-02-14 08:59:19.124350 zmdc[1107].INF-zmdc.pl ['zma -m 2' exited normally]
2020-02-14 08:59:18.079060 zmdc[1107].INF-zmdc.pl ['zmc -m 2' exited normally]
2020-02-14 08:59:17.970043 zmc_m2[8661].INF-zm_ffmpeg.cpp/70 [Queue input is backward in time]
2020-02-14 08:59:17.953980 zmdc[1107].INF-zmdc.pl ['zma -m 2' already running at 20/02/14 08:55:57, pid = 8664]
2020-02-14 08:59:17.918580 zma_m2[8664].INF-zm_event.cpp/588 [Updating frames delta by -0.23 sec to match video file]
2020-02-14 08:59:17.890541 zmc_m2[8661].WAR-zm_ffmpeg.cpp/70 [error while decoding MB 92 50, bytestream -9]
2020-02-14 08:59:17.844860 zmdc[1107].INF-zmdc.pl ['zmc -m 2' sending stop to pid 8661 at 20/02/14 08:59:17]
2020-02-14 08:59:17.779560 zma_m2[8664].INF-zm_monitor.cpp/686 [Monitor-2: image_count:2054 - Closing event 769, shutting down]
2020-02-14 08:59:17.735740 zmdc[1107].INF-zmdc.pl ['zma -m 2' sending stop to pid 8664 at 20/02/14 08:59:17]
2020-02-14 08:59:17.570830 zmwatch[1321].WAR-zmwatch.pl [Restarting capture daemon for Monitor-2, time since last capture 50 seconds (1581692357-1581692307)]
2020-02-14 08:58:27.432611 zmc_m2[8661].INF-zm_monitor.cpp/2546 [Monitor-2: images:2100 - Capturing at 14.29 fps, capturing bandwidth 204256bytes/sec]
2020-02-14 08:58:23.544965 zma_m2[8664].INF-zm_monitor.cpp/1297 [Monitor-2: 2000 - Analysing at 14.29 fps]
2020-02-14 08:58:20.182145 zmc_m2[8661].INF-zm_monitor.cpp/2546 [Monitor-2: images:2000 - Capturing at 12.50 fps, capturing bandwidth 189750bytes/sec]
2020-02-14 08:58:16.368682 zma_m2[8664].INF-zm_monitor.cpp/1297 [Monitor-2: 1900 - Analysing at 14.29 fps]
2020-02-14 08:58:12.889460 zmc_m2[8661].INF-zm_monitor.cpp/2546 [Monitor-2: images:1900 - Capturing at 14.29 fps, capturing bandwidth 210752bytes/sec]
2020-02-14 08:58:09.174552 zma_m2[8664].INF-zm_monitor.cpp/1297 [Monitor-2: 1800 - Analysing at 12.50 fps]
2020-02-14 08:58:05.864189 zmc_m2[8661].INF-zm_monitor.cpp/2546 [Monitor-2: images:1800 - Capturing at 14.29 fps, capturing bandwidth 202306bytes/sec]
2020-02-14 08:58:01.684247 zma_m2[8664].INF-zm_monitor.cpp/1297 [Monitor-2: 1700 - Analysing at 14.29 fps]
I haven't figure anything else out yet.
Did you ever get to the bottom of this I'm having a similar problem with a NEOS camera (which I believe is the same hardware) with DAFANG firmware.
I have exactly same issue. Had you have chance to solve it and get 10min video events?
I my case I get 0:10-1:00min long events...
