Hello, there is a problem when I use LOG_DATABASE_LIMIT e.g. set to 1000 messages. The word "Rows" reserved for mariadb is used in the select statement. I can't find Select Count (*) AS Rows From Logs in the database.php.
Is there a solution or where can I change the word in the script myself?
I use Zoneminder 1.33.16
Best wishes
2020-01-06 18:06:02 web_php 4137 ERR SQL-ERR 'SQLSTATE[42000]: Syntax error or access violation: 1064 You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near 'Rows FROM Logs' at line 1', statement was 'SELECT Count(*) AS Rows FROM Logs' params: /usr/share/zoneminder/www/includes/database.php 152
2020-01-06 18:06:02 web_php 4137 ERR SQL-ERR dbFetchOne no result, statement was 'SELECT Count(*) AS Rows FROM Logs' /usr/share/zoneminder/www/includes/database.php 161
issue LOG_DATABASE_LIMIT - database.php
Re: issue LOG_DATABASE_LIMIT - database.php
I've just pushed a potential fix.
do you already have a solution or are you still working on it
I tried a little more because 1 hour shows too many logs. Deleting only starts at around 15,000 entries.
My guess is that the zmaudit.pl program is not working. There you will find the Select Statement. If I start this program manually at the line level, everything works fine if I replace Rows with another word.
The error message at Zoneminder is still there.
I hope this is still helpful when looking for a possible solution.
zmaudit is not required or recommended.
Logs are cleared on each web ui page request.
I have already committed the fix (I think) you will need to update.
If you are still having the problem please post an updated error message.
Thank you for the quick answer and the possible solution.
However, it is not clear to me what exactly I need to update.
Is it the database.php file?
Thanks again for your help.
