Change StorageAreas to Master
DVB Hardware
Post by DVB Hardware »
What general steps do I need to switch StorageAreas to Master, just switching out the PPA ?
I have a general Idea with using the same DB.
Any Ideas
Jimmy
Re: Change StorageAreas to Master
sudo add-apt-repository ppa:iconnor/zoneminder-master
sudo apt-get install zoneminder
the update can take a while if you have a lot of logs in the Logs table but is otherwise fairly painless.
The biggest thing is that we moved timezone setting from php.ini to Options->Timezone so you will have to set your timezone,
Isaac
gsaindon
Post by gsaindon »
Hi, is the funcitonnality of storage areas included in the master ppa? Should I just switch to he master ppa or the storage-areas ppa will be updated too?
Thanks for your help,
everything has been merged to master.
