First off .. thanks to all who contribute to zoneminder.
I have been happily running 1.33.14 with object detection and upgraded to 1.33.15 with zmeventnotification to 4.6.1. The install completed without errors but I cannot figure out why /usr/share/zoneminder/www/includes/functions.php throws an error from Apache.
From apache error.log
PHP Parse error: syntax error, unexpected ')' in /usr/share/zoneminder/www/includes/functions.php on line 2594
Zoneminder is running and collecting data but can't login to the web UI.
Must be some simple mistake ... anyone?
Upgraded to 1.33.15 and lost web interface
Re: Upgraded to 1.33.15 and lost web interface
I have reports of this, but have been unable to recreate it myself.
Appreciate the reply ...
I commented out the following in function html_radio and the UI is operational but compromised. Is there a way to validate the dataset? There must be corrupt formatting in $attr and/or $value stream that creates the php error.
#$html .= sprintf('
# <div class="form-check%7$s">
# <label class="form-check-label radio%7$s" for="%1$s%6$s%2$s">
# <input class="form-check-input" type="radio" name="%1$s" value="%2$s" id="%1$s%6$s%2$s" %4$s%5$s />
# %3$s</label></div>
# ', $name, $value, $label, ($value==$selected?' checked="checked"':''),
# implode(' ', array_map(
# function($attr, $value){return $attr.'="'.$value.'"';},
# array_keys($attrs),
# array_values($attrs)
# ( isset($options['id']) ? $options['id'] : ''),
# ( ( (!isset($options['inline'])) or $options['inline'] ) ? '-inline' : ''),
#$html .= sprintf('
master has been updated with a fix. There was an extra comma. Still no idea why none of my machines complained.
Excellent .. pulled master and all good!
