I peeled the whole forum, I managed to install zoneminder on ubuntu , to set everything I wanted
I want to thank everyone for sharing and helping.
I created a filter that sent me my detections of movement by email. the problem is the script does not turn into a background spot ...
I have to run to be warned ... so utility is less ...
do you have another filter on event creation can be?
I would like not to see to install script .. use the functions of ZM for ease future maintenance.
Thank you for your help
Email ZM1.32.3
Email ZM1.32.3
- Screenshot_20191203-185014_Chrome.jpg (115.39 KiB) Viewed 1826 times
Re: Email ZM1.32.3
https://wiki.zoneminder.com/How_to_get_ ... Zoneminder
https://wiki.zoneminder.com/SMS_Notific ... ple_Filter
It is possible to run the email filters in the background. See the example filter. You may be missing the -1 minute. Beware of sending anymore than 1 results. When 1 result is sent, it will not send again - it's marked in the db, and you need a new event.
Re: Email ZM1.32.3
Hello and thank yousnake wrote: ↑Wed Dec 04, 2019 2:45 pm https://wiki.zoneminder.com/How_to_get_ ... Zoneminder
so I used:Example Filter
Weekday equal to Saturday OR
Weekday equal to Sunday AND
date / time greater than or equal to -1 minute AND
as I wish to watch every day!
I try this new configuration and come back to you
- Screenshot_20191205-080055_Chrome.jpg (131.19 KiB) Viewed 1789 times
Re: Email ZM1.32.3
It does not work ...
The criteria of my old filter are valid. when I manually execute it I receive the alarms! How can I verify that it turns out well in the background?
Thank you
Thank you
Re: Email ZM1.32.3
Those two links have all the troubleshooting instructions you need
e.g.
from: https://wiki.zoneminder.com/SMS_Notific ... _the_email
e.g.
It appears that English is not your first language, so let me know if it is not clear, and possibly try online translation."First, run a filter in the background (see tips below). Do not try to submit / execute. Second, Enable logging on /var/log/zm folder. Third, tail the ZMFilter log and syslog. Fourth, to initiate an alarm (if alarms are used to test emails), use 'force alarm' on the monitor screen. That is, view a camera, and click force alarm.
You should see SSMTP send an email on the syslog (or try) and the zmfilter log will report the trigger."
