RSTP connection issues
Re: RSTP connection issues
Post by bbunge » Mon Oct 07, 2019 2:26 am
Switch the os on the Pi to Ubuntu 18.04. There are images for the Pi in armhf and arm64 that work very well. Then you can run a more recent Zoneminder from the zmrepro. You can pull your hair out forever trying to get Zoneminder to work well on raspbian.
Sorry I did not see you had a Pi sooner.
kitkat
Post by kitkat » Thu Oct 10, 2019 6:16 pm
blax wrote:
Mon Sep 23, 2019 7:24 am
Camera resolution in VLC :
Codec MPEG-H Part2/HEVC (H.265)
Video resolution 1920x1080
blax wrote:
Fri Sep 27, 2019 9:08 am
VLC is still working getting the image...but still no success with "zombie minder" ^^
But in zm logs i found these lines
WAR : [The device is using a codec that may not be supported. Do not be surprised if things don't work.]
Maybe try switching the camera's output format to H.264?
blax
Post by blax » Mon Oct 14, 2019 2:29 pm
Hi guys, back from holidays ^^
So i tried :
- removing max fps setting
- Updating chromium
- using zm with firefox ers
- lower the resolution to 640 x 480
but still no results except blank page :)
kitkat
Post by kitkat » Mon Oct 14, 2019 2:45 pm
Is the Method on the Source tab set to TCP? My RTSP cameras only work with that.
blax
Post by blax » Thu Oct 17, 2019 6:46 am
I only have :
RTP/Unicast
RTP/Multicast
RTP/RTSP
RTP/RTSP/HTTP
Not TCP option
Users browsing this forum: No registered users and 14 guests
