Update to 1.33.9
gsaindon
Update to 1.33.9
Post by gsaindon »
I get this error updating to 1.33.9
The following packages have unmet dependencies:
zoneminder : Depends: libssl but it is not installable
Recommends: zoneminder-doc (>= 1.33.9~20190517112457-xenial) but 1.33.8~20190506105058-xenial is to be installed
E: Unable to correct problems, you have held broken packages.
Thanks,
DVB Hardware
Re: Update to 1.33.9
Post by DVB Hardware »
I cannot upgrade 1.33.8 on Linux mint 19.1 via ppa or terminal it is like 1.33.9 does not exist
Jimmy
Linux Mint 21 Cinnamon Mariadb 10.6.x using Master 1.37.x latest always
I think v 1.33.8 is the zoneminder-master and v 1.33.9 is zoneminder-storageareas. It appears that the work on storageareas which iconner does the main experimentation and development on before it is pushed to the master branch, is not quite ready to be integrated into the master.
try using
sudo add-apt-repository ppa:iconnor/zoneminder-storageareas
sudo apt-get updat
e
DVB Hardware
That is what I have been using for a long time, always updating on each new release
Always the master updates before storageareas...not this time
https://launchpad.net/~iconnor/+archive ... orageareas
asker
Post by asker »
I just built 1.33.9 in Storage Areas on ubuntu 16. There was a problem with the ssl lib. When Isaac deploys the update, I think it should work.
Please read before posting:
ES docs
zmNinja docs
DVB Hardware
Ok thanks, will wait for update, I least I know where the problem is
Jimmy
asker
Post by asker »
Actually, my comment was for the OP who posted the libssl issue. That was a problem. I don't know how Isaac manages the packages for different distros/etc. So I'm not sure if you will see if for Linux Mint.
ES docs
zmNinja docs
DVB Hardware
Storageareas 1.33.9~20190519084612-bionic PPA just released...upgrade success
Jimmy
New packages should be available now.
