I'm running with a multi server setup, 4 servers in total. Three of the servers handle the Hi-Res camera feeds and the forth looks after all of the Lo-Res cameras feeds. This fourth server is were I proxy to over the Internet via Nginx. Here's my Nginx config.
server {
server_name zoneminder.mycyberspace.co.uk;
server_name zm04.cctv.mycyberspace.co.uk;
server_name zm03.cctv.mycyberspace.co.uk;
server_name zm02.cctv.mycyberspace.co.uk;
server_name zm01.cctv.mycyberspace.co.uk;
server_name zm04.cctv.mycyberspace.net;
server_name zm03.cctv.mycyberspace.net;
server_name zm02.cctv.mycyberspace.net;
server_name zm01.cctv.mycyberspace.net;
location / {
proxy_pass http://zm04.cctv.mycyberspace.net;
proxy_set_header Host $http_host;
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for
proxy_set_header X-Forwarded-Proto $scheme;
location /zm/cgi-bin {
auth_basic off;
alias /usr/libexec/zoneminder/cgi-bin;
include fastcgi_params;
fastcgi_param SCRIPT_FILENAME $request_filename;
fastcgi_param HTTP_PROXY "";
fastcgi_pass unix:/var/run/fcgiwrap.socket;
location /zm/cache {
auth_basic off;
alias /var/cache/zoneminder;
location ~ /zm/api/(css|img|ico) {
auth_basic off;
rewrite ^/zm/api(.+)$ /api/app/webroot/$1 break;
try_files $uri $uri/ =404;
listen 80;
Thanks in advance.
Garry
