AXIS Companion Dome V
dmiller
Post by dmiller »
Hi!
I try to connect my new AXIS Companion Dome V cameras to ZM, 1.30.4.
But I have no luck..
Have almost tried all combinations of parameters...
Anyone having parameters for this one?
Thanks!
D
Plugmusc
Re: AXIS Companion Dome V
Post by Plugmusc »
I'm having the same problem with this camera. Has anyone been able to work out the correct settings?
Many thanks,
Dave.
nilsoskar
Post by nilsoskar »
Has anyone managed to find the settings for this device?
I can connect to it if I allow Anonymous viewers but I feel it is not a long term solution.
Regards,
Nils
dmiller
Post by dmiller »
How did you config Zone Minder to connect to the camera as a anonymous viewer?
What about the performance?
nilsoskar wrote: Mon May 21, 2018 10:09 am Hello,
Regards,
Nils
snake
Post by snake »
It looks like the "companion series" has closed the MJPEG and RTSP urls.
Would also like to know how to connect via any means.
There is an outdoor companion cam for a reasonable price, but if it's not compatible with ZM, then I have to buy from other vendors...
tobelger
Post by tobelger »
Hi, i get Video with following URLS to Axis Companion Dome mini LE on Zoneminder 1.34.16:
rtsp://root:password@camera/axis-media/media.amp/?overview=0&Axis-Orig-Sw=true
http://user:password@camera/mjpg/1/vide ... ig-Sw=true
