This has been working fine till recent update.
When I select 2 wide from layout and refresh, layout show freeform still and I see cameras vertical.
This occurs on every browser IE, Edge, Firefox, and Chrome.
During the update I did run data conversion. I also updated http config file with what was provided.
I have this version.
zoneminder-httpd-1.32.3-1.fc29.x86_64
zoneminder-common-1.32.3-1.fc29.x86_64
zoneminder-1.32.3-1.fc29.x86_64
Thank you,
Durwin
Montage layout shows vertical only
Re: Montage layout shows vertical only
Check for javascript errors. Right click -> inspect element -> console
Thank you. After I set layout to 2 wide and refresh page I see this (using IE).
HTML1308: Navigation occurred.
index.php
SCRIPT1002: Syntax error
js_Server-classic-1544278956.js (1,1)
SCRIPTl002: Syntax error
index.php (135,42)
SCRIPT5009: 'monitorData' is undefined
skins_c1assic_views_js_montage-c1assic-1544278956.js (1,1)
HTML1423: Malformed start tag. Attributes should be separated by whitespace.
index.php (187,18)
HTML1506: Unexpected token.
index.php (326,3)
SEC7115: :visited and :link styles can only differ by color. Some styles were not applied to :visited.
index.php
index.php
index.php (135,42)
index.php (187,18)
index.php (326,3)
index.php
