Latest image
Maximo1970
Latest image
Post by Maximo1970 » Fri Jan 19, 2018 1:05 pm
Hi Everyone,
I've done a search of the forum and not found the answer, although it appears to have been asked in different ways a few times in the past.
I'm currently building a home automation system that can interface with Zoneminder for controls and events. As part of my solution I'd like to be able to display the most recently captured image from each of my cameras. I'm not looking for a live feed as that would create to much load both across my network and on the servers that make up my home automation solution. What I'm looking for is either the last image from a motion event or an image that's sort of in a timelapse, say every 90 seconds.
Does anyone have any suggestions on what's possible?
Cheers,
Garry
Paranoid
Re: Latest image
Post by Paranoid » Fri Jan 19, 2018 4:22 pm
You can grab the latest image with the following command:
zmu -m 1 -i -U username -P password
Run it every 90 seconds (or however often you want) and store the image on a web server so you can grab it whenever you want.
Re: Latest image
Post by rockedge » Sun Jan 21, 2018 12:47 am
or something like this for monitor 1 in this example:
http://your-zm-server/cgi-bin/nph-zms?mode=single&scale=100&monitor=1
Maximo1970
Re: Latest image
Post by Maximo1970 » Thu Jan 25, 2018 10:11 am
Thanks guys, very helpful.
Undutchable
Re: Latest image
Post by Undutchable » Tue Aug 14, 2018 12:27 pm
Hi Maximo,
I'm also interested in such solution for HA.
How did you accomplish the 90 sec interval grabbing?
Maximo1970
Re: Latest image
Post by Maximo1970 » Fri Aug 17, 2018 11:26 am
I'll be honest and say I got distracted by another project and didn't fully implement this. I did trial it out to start with, and just used the URL access within a screen page on my HA solution, but couldn't get a clean enough image. Hence why I got distracted.
