[problem] Zoneminder several crash
vox
Post by vox » Tue Nov 07, 2017 1:48 pm
System : ubuntu 16.04
ZM version : 1.30.4
DataBase : mariadb 10.2 + galera 3 (cluster)
Bug : several crash
First, i have try to re-installs and reboots, it's change nothing.
In my log i can watch some informations about "Segmentation fault". I edit my post after for add screenshot and more informations.
Actually for it's work i need start ZM via cron all 15 seconds and that add some problems on my machine (reboot really bug).
screenshot-2017_11_07-Zoneminder-Bug-Several_Crash-Demo-Continuous_record_have_bug.png
screenshot-2017_11_07-Zoneminder-Bug-Several_Crash-Demo-Continuous_record_have_bug.png (52.74 KiB) Viewed 5944 times
Re: [problem] Zoneminder several crash
Post by bbunge » Wed Nov 08, 2017 2:38 am
With the numbe of cameras you have it may be possoble you are running out of memory, tmpfs. Reduce the resolution and frame rate on your cameras. Also check the WIKI for the install instructions to see if you missed something.
vox
Post by vox » Wed Nov 08, 2017 1:30 pm
Many thanks for your helping @bbunge
Ok i try : i have stop 3 cams and decreases the quality of the main cam.
I test during some hours and post a new message with fresh informations from the battleground :)
Hmmm it's my 3th install (on the same machine after reset) and the last install do not have this bug with full FPS and HD. But it's my first in Multi-Server mod with Database clustering.
All my installation procedure is indicated here in french : [Tuto/HowTo] Installer zoneminder sur ubuntu 16.04, [Tuto/HowTo] [Ubuntu] système distribué de caméra vidéos surveillance and [EN] [Tuto/HowTo] ZoneMinder Optimizations
I have this bug too on this install when i have only two cameras.
Some times when i change the config of one camera and save, ZoneMinder crash.
Sorry for my not terrible english.
vox
Post by vox » Wed Nov 08, 2017 2:15 pm
This post receive edit during the day.
Logs after a crash with 2 cams (1 in Modect and 1 in Mocord). On my last ZM install this config don't have this bug.
screenshot-2017_11_08-ZoneMinder-Logs-Crash_at_15h03_With_1cam_Modect_and_1cam_Mocord.png
screenshot-2017_11_08-ZoneMinder-Logs-Crash_at_15h03_With_1cam_Modect_and_1cam_Mocord.png (76.01 KiB) Viewed 5916 times
With this config (1 cam modect + 1 cam mocord) the bug is not solved
  • creenshot-2017_11_08-Zoneminder-Bug-Several_Crash-Demo-Continuous_record_have_bug-mocord.png
    creenshot-2017_11_08-Zoneminder-Bug-Several_Crash-Demo-Continuous_record_have_bug-mocord.png (45.76 KiB) Viewed 5907 times
Post by bbunge » Wed Nov 08, 2017 3:39 pm
Couol be the multi server mode.
Your English is better than my Francais!
vox
Post by vox » Mon Nov 13, 2017 1:56 pm
Please anybody for help me to search how to solve these really boring crash :(
osk
Post by osk » Mon Nov 13, 2017 3:39 pm
Hi
I had a lot of errors similar what you have, like "zmc -m 4' has not stopped at 17/10/15 07:15:09. Sending KILL to pid 10474" or "'zma -m 2' exited abnormally, exit status 255]". Root cause for these errors was missing keepalive message in REMOTE RTSP protocol.
I manually forced keepalive messages by altering the code in zm_rtsp.cpp:
Line 365 in zm_rtsp.cpp
-- bool sendKeepalive = false;
++ bool sendKeepalive = true;
Line 508 in zm_rtsp.cpp
-- int timeout = 0;
++ int timeout = 60;
This change made the trick and now all my cameras have been now working over a week without any jamming.
I think that ZoneMinder monitor configuration should have an option to force keepalive message sending. Most likely my cameras are not the only ones needing keepalive messages...
Cheers
osk
vox
Post by vox » Tue Nov 14, 2017 2:19 pm
do you have the path for modify the file please? :)
osk
Post by osk » Tue Nov 14, 2017 7:14 pm
here are all the steps I made to fix this error (Ubuntu 17.10):
Get build dependencies
sudo apt build-dep zoneminder
Get ZoneMinder sources (To be able to get the sources you have to enable "Source Code" selection in "Software & Updates")
apt source zoneminder
Fix the build error in zoneminder-1.30.4+dfsg/src/zm_comms.h by adding line
#include <sys/uio.h>
Edit zoneminder-1.30.4+dfsg/src/zm_rtsp.cpp:
-- int timeout = 0;
Compile sources
apt-get --compile source zoneminder
Install compiled version
sudo dpkg -i zoneminder_1.30.4+dfsg-2_amd64.deb
Cheers
osk
vox
Post by vox » Tue Nov 14, 2017 8:26 pm
Cheers
osk
Really thanks Osk, i try tomorrow and post if it's working or not :)
With this method, what hapenning to zoneminder if i apt-get dist-upgrade ?
apt source zoneminder => that download in the current folder of the shell session? :)
osk
Post by osk » Wed Nov 15, 2017 8:50 am
Well, my zomenider build last week was the first time I ever built something from sources, so I am not an expert here...
I suppose that apt dist-upgrade and even apt upgrade will replace the self-built zoneminder with distribution's original version unless you remove the default zoneminder package with apt remove.
Yes, it downloads the sources to current directory. I used instructions from this page when I built zoneminder: https://askubuntu.com/questions/28372/h ... gh-apt-get
Cheers
osk
vox
Post by vox » Wed Nov 15, 2017 1:00 pm
and
said : "You must insert some "source" addresses into your sources."
and theses instruction at the command "./do_debian_package.sh `lsb_release -a 2>/dev/null | grep Codename | awk '{print $2}'` `date +%Y%m%d`01 local stable" respond "Unknown option xenial, continue? (Y|n)n".
osk
Post by osk » Wed Nov 15, 2017 3:39 pm
Run application "Software & Updates" and tick box "Source Code",
Cheers
osk
vox
Post by vox » Wed Nov 15, 2017 3:47 pm
it's a server without GUI, command line only ^ ^
osk
Post by osk » Wed Nov 15, 2017 4:02 pm
If you're running it from command line, the the application name is software-properties-gtk
Users browsing this forum: No registered users and 12 guests
