I've been crawling numerous threads where nearly the same answer is being applied where it is not a sollution for me;
Whenever I open the "Cycle/Montage" view the chrome console tells me that
/zm/cgi-bin/nph-zms
Server info;
OS: Debian 8
Interface: Open Media Vault
Zoneminder: v.1.29.0
When I open the NGINX log I see the following:
2017/08/12 16:43:37 [error] 2399#0: *83 FastCGI sent in stderr: "PHP message: ERR [socket_sendto( /var/run/zm/zms-759779s.sock ) failed: No such file or directory]" while reading response header from upstream, client: 192.168.1.73, server: , request: "POST /index.php HTTP/1.1", upstream: "fastcgi://unix:/var/run/fpm-d93d75cf-7eec-4480-8581-d349a88c225c.sock:", host: "192.168.1.250:81", referrer: "http://192.168.1.250:81/index.php?view=montage&group=0"
2017/08/12 16:44:01 [error] 2399#0: *81 FastCGI sent in stderr: "PHP message: ERR [socket_sendto( /var/run/zm/zms-303671s.sock ) failed: No such file or directory]" while reading response header from upstream, client: 192.168.1.73, server: , request: "POST /index.php HTTP/1.1", upstream: "fastcgi://unix:/var/run/fpm-d93d75cf-7eec-4480-8581-d349a88c225c.sock:", host: "192.168.1.250:81", referrer: "http://192.168.1.250:81/index.php?view=montage&group=0"
2017/08/12 16:44:03 [error] 2399#0: *83 FastCGI sent in stderr: "PHP message: ERR [socket_sendto( /var/run/zm/zms-759779s.sock ) failed: No such file or directory]" while reading response header from upstream, client: 192.168.1.73, server: , request: "POST /index.php HTTP/1.1", upstream: "fastcgi://unix:/var/run/fpm-d93d75cf-7eec-4480-8581-d349a88c225c.sock:", host: "192.168.1.250:81", referrer: "http://192.168.1.250:81/index.php?view=montage&group=0"
2017/08/12 16:44:14 [error] 2399#0: *83 FastCGI sent in stderr: "PHP message: ERR [socket_sendto( /var/run/zm/zms-303671s.sock ) failed: No such file or directory]" while reading response header from upstream, client: 192.168.1.73, server: , request: "POST /index.php HTTP/1.1", upstream: "fastcgi://unix:/var/run/fpm-d93d75cf-7eec-4480-8581-d349a88c225c.sock:", host: "192.168.1.250:81", referrer: "http://192.168.1.250:81/index.php?view=montage&group=0"
2017/08/12 16:44:16 [error] 2399#0: *81 FastCGI sent in stderr: "PHP message: ERR [socket_sendto( /var/run/zm/zms-759779s.sock ) failed: No such file or directory]" while reading response header from upstream, client: 192.168.1.73, server: , request: "POST /index.php HTTP/1.1", upstream: "fastcgi://unix:/var/run/fpm-d93d75cf-7eec-4480-8581-d349a88c225c.sock:", host: "192.168.1.250:81", referrer: "http://192.168.1.250:81/index.php?view=montage&group=0"
2017/08/12 16:44:27 [error] 2399#0: *81 FastCGI sent in stderr: "PHP message: ERR [socket_sendto( /var/run/zm/zms-303671s.sock ) failed: No such file or directory]" while reading response header from upstream, client: 192.168.1.73, server: , request: "POST /index.php HTTP/1.1", upstream: "fastcgi://unix:/var/run/fpm-d93d75cf-7eec-4480-8581-d349a88c225c.sock:", host: "192.168.1.250:81", referrer: "http://192.168.1.250:81/index.php?view=montage&group=0"
2017/08/12 16:44:29 [error] 2399#0: *83 FastCGI sent in stderr: "PHP message: ERR [socket_sendto( /var/run/zm/zms-759779s.sock ) failed: No such file or directory]" while reading response header from upstream, client: 192.168.1.73, server: , request: "POST /index.php HTTP/1.1", upstream: "fastcgi://unix:/var/run/fpm-d93d75cf-7eec-4480-8581-d349a88c225c.sock:", host: "192.168.1.250:81", referrer: "http://192.168.1.250:81/index.php?view=montage&group=0"
2017/08/12 16:44:40 [error] 2399#0: *83 FastCGI sent in stderr: "PHP message: ERR [socket_sendto( /var/run/zm/zms-303671s.sock ) failed: No such file or directory]" while reading response header from upstream, client: 192.168.1.73, server: , request: "POST /index.php HTTP/1.1", upstream: "fastcgi://unix:/var/run/fpm-d93d75cf-7eec-4480-8581-d349a88c225c.sock:", host: "192.168.1.250:81", referrer: "http://192.168.1.250:81/index.php?view=montage&group=0"
2017/08/12 16:44:42 [error] 2399#0: *81 FastCGI sent in stderr: "PHP message: ERR [socket_sendto( /var/run/zm/zms-759779s.sock ) failed: No such file or directory]" while reading response header from upstream, client: 192.168.1.73, server: , request: "POST /index.php HTTP/1.1", upstream: "fastcgi://unix:/var/run/fpm-d93d75cf-7eec-4480-8581-d349a88c225c.sock:", host: "192.168.1.250:81", referrer: "http://192.168.1.250:81/index.php?view=montage&group=0"
2017/08/12 16:44:53 [error] 2399#0: *81 FastCGI sent in stderr: "PHP message: ERR [socket_sendto( /var/run/zm/zms-303671s.sock ) failed: No such file or directory]" while reading response header from upstream, client: 192.168.1.73, server: , request: "POST /index.php HTTP/1.1", upstream: "fastcgi://unix:/var/run/fpm-d93d75cf-7eec-4480-8581-d349a88c225c.sock:", host: "192.168.1.250:81", referrer: "http://192.168.1.250:81/index.php?view=montage&group=0"
2017/08/12 16:44:55 [error] 2399#0: *166 FastCGI sent in stderr: "PHP message: ERR [socket_sendto( /var/run/zm/zms-759779s.sock ) failed: No such file or directory]" while reading response header from upstream, client: 192.168.1.73, server: , request: "POST /index.php HTTP/1.1", upstream: "fastcgi://unix:/var/run/fpm-d93d75cf-7eec-4480-8581-d349a88c225c.sock:", host: "192.168.1.250:81", referrer: "http://192.168.1.250:81/index.php?view=montage&group=0"
2017/08/12 16:45:06 [error] 2399#0: *166 FastCGI sent in stderr: "PHP message: ERR [socket_sendto( /var/run/zm/zms-303671s.sock ) failed: No such file or directory]" while reading response header from upstream, client: 192.168.1.73, server: , request: "POST /index.php HTTP/1.1", upstream: "fastcgi://unix:/var/run/fpm-d93d75cf-7eec-4480-8581-d349a88c225c.sock:", host: "192.168.1.250:81", referrer: "http://192.168.1.250:81/index.php?view=montage&group=0"
I've been struggling at first for quite a while to get the nginx configuration working as I didn't know where to place this.
zz-omv-nginx.conf contents;
server {
listen 81;
listen [::]:81;
set $root_path "/mnt/data/webserver/secnet";
root $root_path;
index index.html;
set $socket "unix:/var/run/fpm-d93d75cf-7eec-4480-8581-d349a88c225c.sock";
location ~ \.php$ {
include snippets/fastcgi-php.conf;
fastcgi_pass $socket;
access_log /var/log/nginx/3e553d85-5354-4319-9deb-88fc1f3ae805-access.log;
error_log /var/log/nginx/3e553d85-5354-4319-9deb-88fc1f3ae805-error.log;
large_client_header_buffers 4 8k;
location /zm/cgi-bin {
gzip off;
alias /usr/lib/cgi-bin;
include /etc/nginx/fastcgi_params;
fastcgi_param SCRIPT_FILENAME $request_filename;
fastcgi_pass unix:/var/run/fcgiwrap.socket;
location /zm {
gzip off;
alias /usr/share/zoneminder;
index index.php;
location ~ \.php$ {
if (!-f $request_filename) { return 404; }
expires epoch;
fastcgi_index index.php;
fastcgi_pass unix:/var/run/php5-fpm.sock;
location ~ \.(jpg|jpeg|gif|png|ico)$ {
access_log off;
expires 33d;
location /zm/api/ {
alias /usr/share/zoneminder/api;
rewrite ^/zm/api(.+)$ /zm/api/index.php?p=$1 last;
I already have 2 camera's configured which are working, as when I click on "zone" in the camera overview I see a snapshot of that moment.
I'm extremely thankful to the person(s) that are willing to help me solve this issue, or that happen to resolve it for/with me!
(If any information is left out, please ask me and I'll provide whatever I can!)
