I tried the above to install apcu, but get errors.
I am trying to get my mobile app to work, it keeps saying invalid API.
API access failed, please make sure APIs configured correctly.
I tested:
zm/api/monitors.json , this works zm/api/events.json, works as well
I can get the version
a) Distro: Ubuntu 14.04
b) ZM : 1.30.4
c) I am using aws machine and to upgrade i just had some notice that said I could upgrade in my UI and said okay.
1.30.2 upgrade breaks API access
Re: 1.30.2 upgrade breaks API access
Hello
I am stuck running 1.30.2 because upgrading to 1.30.4 or 1.31.x breaks my API access. I am running Ubuntu 16.04
xxxx@xxxx:/var/log/apache2$ sudo apt-get install php5-apcu
Reading package lists... Done
Building dependency tree
Reading state information... Done
E: Unable to locate package php5-apcu
xxxx@xxxx:/var/log/apache2$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 16.04.2 LTS
Release: 16.04
Codename: xenial
From my apache.log file I get this when trying to access API's.
[Sun Jul 09 12:10:56.039929 2017] [:error] [pid 22210] [client 1.2.3.4:50252] PHP Fatal error: Call to undefined function apc_fetch() in /usr/share/zoneminder/www/api/lib/Cake/Cache/Engine/ApcEngine.php on line 78
Several posts seem to indicate that php5-apcu is what is needed, but I can't figure out how to install that on Ubuntu 16.04. Can anyone help?
Release: 16.04
Codename: xenial
Make sure that the php5-apcu module is activated! Simply put, check that the apcu.ini is symlinked from /etc/php5/mods-available/apcu.ini to /etc/php5/cgi/conf.d/apcu.ini
you can use a2enmod to do this.
important: restart the Apache server!
then in a browser test the API by logging into ZM and then using the URL -> http://your_zm_server_ip/zm/api/host/getVersion.json
you should see something like this ->
I hope this helps.
{"version":"1.31.1","apiversion":"1.0"}
Hi thanks for the advice but unfortunately it appears that I do not have php5-apcu installed. It seems that it is not possible to install that package on Ubuntu 16.04?
https://www.howtoforge.com/tutorial/ins ... 6-04-lamp/PHP 7 ships with a built-in opcode cacher for caching and optimizing PHP intermediate code, it has the name 'opcache' and is available in the package php7.0-opcache. It is strongly recommended to have an Opcache installed to speed up your PHP page. Besides opcache, I will install APCu which is a compatibility wrapper for opcache to provide the functions of the APC cache, an often used caching system in php 5.x versions and many CMS systems still use it.
what version of PHP is running on your system?
I think you can open a terminal and use for PHP 7 ->
apt-get -y install php7.0-opcache php-apcu
systemctl restart apache2
thanks for the link. It took multiple steps. I'm not sure what I did, but everything seems to be working now. In case others find this problem, the steps to resolve were something like this.
sudo apt-get -f install
apt-get -y install php7.0 libapache2-mod-php7.0 -f
had to edit some timezone settings in a php.ini config file
sudo apt install libapache2-mod-php
sudo a2dismod php5
sudo a2enmod php7.0
sudo service apache2 restart
thanks again, Rockedge!
sudo a2dismod php5
sudo a2enmod php7.0
