Linux version 2.6.18-4-686 (Debian 2.6.18.dfsg.1-11) (
waldi@debian.org) (gcc version 4.1.2 20061115 (prerelease) (Debian 4.1.1-21)) #1 SMP Wed Feb 21 16:06:7BIOS-provided physical RAM map:
BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
BIOS-e820: 00000000000c8000 - 00000000000cc000 (reserved)
BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
BIOS-e820: 0000000000100000 - 000000001fff0000 (usable)
BIOS-e820: 000000001fff0000 - 000000001fff8000 (ACPI data)
BIOS-e820: 000000001fff8000 - 0000000020000000 (ACPI NVS)
BIOS-e820: 00000000fff00000 - 0000000100000000 (reserved)
0MB HIGHMEM available.
511MB LOWMEM available.
found SMP MP-table at 000fba60
On node 0 totalpages: 131056
DMA zone: 4096 pages, LIFO batch:0
Normal zone: 126960 pages, LIFO batch:31
DMI 2.3 present.
ACPI: RSDP (v000 COMPAQ ) @ 0x000fa380
ACPI: RSDT (v001 COMPAQ INTEL845 0x00000010 MSFT 0x00000097) @ 0x1fff0000
ACPI: FADT (v001 COMPAQ INTEL845 0x00000011 MSFT 0x00000097) @ 0x1fff0030
ACPI: MADT (v001 COMPAQ 0x00000009 MSFT 0x00000097) @ 0x1fff00b0
ACPI: DSDT (v001 INTEL BROKDALE 0x00001000 MSFT 0x0100000d) @ 0x00000000
ACPI: PM-Timer IO Port: 0x808
ACPI: Local APIC address 0xfee00000
ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
Processor #0 15:2 APIC version 20
ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-23
ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
ACPI: IRQ0 used by override.
ACPI: IRQ2 used by override.
ACPI: IRQ9 used by override.
Enabling APIC mode: Flat. Using 1 I/O APICs
Using ACPI (MADT) for SMP configuration information
Allocating PCI resources starting at 30000000 (gap: 20000000:dff00000)
Detected 2399.705 MHz processor.
Built 1 zonelists. Total pages: 131056
Kernel command line: root=/dev/hda1 console=tty0 console=ttyS0,9600n8 ro
mapped APIC to ffffd000 (fee00000)
mapped IOAPIC to ffffc000 (fec00000)
Enabling fast FPU save and restore... done.
Enabling unmasked SIMD FPU exception support... done.
Initializing CPU#0
PID hash table entries: 2048 (order: 11, 8192 bytes)
Console: colour VGA+ 80x25
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 512048k/524224k available (1544k kernel code, 11552k reserved, 577k data, 196k init, 0k highmem)
Checking if this processor honours the WP bit even in supervisor mode... Ok.
Calibrating delay using timer specific routine.. 4803.28 BogoMIPS (lpj=9606567)
Security Framework v1.0.0 initialized
SELinux: Disabled at boot.
Capability LSM initialized
Mount-cache hash table entries: 512
CPU: After generic identify, caps: bfebfbff 00000000 00000000 00000000 00004400 00000000 00000000
CPU: After vendor identify, caps: bfebfbff 00000000 00000000 00000000 00004400 00000000 00000000
CPU: Trace cache: 12K uops, L1 D cache: 8K
CPU: L2 cache: 512K
CPU: Hyper-Threading is disabled
CPU: After all inits, caps: bfebfbff 00000000 00000000 00000080 00004400 00000000 00000000
Intel machine check architecture supported.
Intel machine check reporting enabled on CPU#0.
CPU0: Intel P4/Xeon Extended MCE MSRs (12) available
CPU0: Thermal monitoring enabled
Compat vDSO mapped to ffffe000.
Checking 'hlt' instruction... OK.
SMP alternatives: switching to UP code
Freeing SMP alternatives: 16k freed
ACPI: Core revision 20060707
CPU0: Intel(R) Pentium(R) 4 CPU 2.40GHz stepping 09
Total of 1 processors activated (4803.28 BogoMIPS).
ENABLING IO-APIC IRQs
..TIMER: vector=0x31 apic1=0 pin1=2 apic2=-1 pin2=-1
Brought up 1 CPUs
migration_cost=0
checking if image is initramfs... it is
Freeing initrd memory: 4375k freed
NET: Registered protocol family 16
ACPI: bus type pci registered
PCI: PCI BIOS revision 2.10 entry at 0xfdb61, last bus=3
PCI: Using configuration type 1
Setting up standard PCI resources
ACPI: Interpreter enabled
ACPI: Using IOAPIC for interrupt routing
ACPI: PCI Root Bridge [PCI0] (0000:00)
PCI: Probing PCI hardware (bus 00)
PCI quirk: region 0800-087f claimed by ICH4 ACPI/GPIO/TCO
PCI quirk: region 0400-043f claimed by ICH4 GPIO
PCI: Firmware left 0000:02:08.0 e100 interrupts enabled, disabling
Boot video device is 0000:02:0b.0
PCI: Transparent bridge - 0000:00:1e.0
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.ICHB._PRT]
ACPI: Power Resource [URP1] (off)
ACPI: Power Resource [URP2] (off)
ACPI: Power Resource [FDDP] (off)
ACPI: Power Resource [LPTP] (off)
ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 *6 7 10 11 12 14 15)
ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 7 10 *11 12 14 15)
ACPI: PCI Interrupt Link [LNKD] (IRQs 9) *10
ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 *5 6 7 10 11 12 14 15)
ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 10 *11 12 14 15)
ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 *7 10 11 12 14 15)
ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
Linux Plug and Play Support v0.97 (c) Adam Belay
pnp: PnP ACPI init
pnp: PnP ACPI: found 11 devices
PnPBIOS: Disabled by ACPI PNP
PCI: Using ACPI for IRQ routing
PCI: If a device doesn't work, try "pci=routeirq". If it helps, post a report
PCI: BIOS reporting unknown device 02:59
PCI: Bridge: 0000:00:01.0
IO window: disabled.
MEM window: df800000-df8fffff
PREFETCH window: df400000-df4fffff
PCI: Bridge: 0000:02:0f.0
MEM window: df900000-df9fffff
PREFETCH window: df500000-df5fffff
PCI: Bridge: 0000:00:1e.0
IO window: c000-cfff
MEM window: df900000-dfefffff
PREFETCH window: df500000-df6fffff
PCI: Setting latency timer of device 0000:00:1e.0 to 64
NET: Registered protocol family 2
IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
TCP established hash table entries: 16384 (order: 5, 131072 bytes)
TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
TCP: Hash tables configured (established 16384 bind 8192)
TCP reno registered
audit: initializing netlink socket (disabled)
audit(1173355629.444:1): initialized
VFS: Disk quotas dquot_6.5.1
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Initializing Cryptographic API
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered (default)
isapnp: Scanning for PnP cards...
isapnp: No Plug & Play device found
Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
serial8250: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
00:09: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
00:0a: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
RAMDISK driver initialized: 16 RAM disks of 8192K size 1024 blocksize
PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
serio: i8042 AUX port at 0x60,0x64 irq 12
serio: i8042 KBD port at 0x60,0x64 irq 1
mice: PS/2 mouse device common for all mice
TCP bic registered
NET: Registered protocol family 17
NET: Registered protocol family 8
NET: Registered protocol family 20
Using IPI No-Shortcut mode
ACPI: (supports<6>Time: tsc clocksource has been installed.
S0 S1 S3 S4 S5)
Freeing unused kernel memory: 196k freed
input: AT Translated Set 2 keyboard as /class/input/input0
ACPI: Processor [CPU1] (supports 8 throttling states)
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
ICH2: IDE controller at PCI slot 0000:00:1f.1
ICH2: chipset revision 5
ICH2: not 100% native mode: will probe irqs later
ide0: BM-DMA at 0xfc00-0xfc07, BIOS settings: hda:DMA, hdb:pio
ide1: BM-DMA at 0xfc08-0xfc0f, BIOS settings: hdc:DMA, hdd:pio
Probing IDE interface ide0...
usbcore: registered new driver usbfs
usbcore: registered new driver hub
USB Universal Host Controller Interface driver v3.0
e100: Intel(R) PRO/100 Network Driver, 3.5.10-k2-NAPI
e100: Copyright(c) 1999-2005 Intel Corporation
hda: ST360020A, ATA DISK drive
ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
Probing IDE interface ide1...
hdc: TOSHIBA ODD-DVD SD-R5272, ATAPI CD/DVD-ROM drive
ide1 at 0x170-0x177,0x376 on irq 15
ACPI: PCI Interrupt 0000:00:1f.2[D] -> GSI 19 (level, low) -> IRQ 169
PCI: Setting latency timer of device 0000:00:1f.2 to 64
uhci_hcd 0000:00:1f.2: UHCI Host Controller
uhci_hcd 0000:00:1f.2: new USB bus registered, assigned bus number 1
uhci_hcd 0000:00:1f.2: irq 169, io base 0x0000ec00
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
hda: max request size: 128KiB
hda: 117231408 sectors (60022 MB) w/2048KiB Cache, CHS=65535/16/63, UDMA(100)
hda: cache flushes not supported
hda: hda1 hda2 < hda5 > hda3
ACPI: PCI Interrupt 0000:02:08.0[A] -> GSI 20 (level, low) -> IRQ 177
e100: eth0: e100_probe: addr 0xdfedf000, irq 177, MAC addr 00:C0:A8:FA:6E:E4
hdc: ATAPI 40X DVD-ROM DVD-R CD-R/RW drive, 2048kB Cache, UDMA(33)
Uniform CD-ROM driver Revision: 3.20
Attempting manual resume
kjournald starting. Commit interval 5 seconds
EXT3-fs: mounted filesystem with ordered data mode.
Real Time Clock Driver v1.12ac
pci_hotplug: PCI Hot Plug PCI Core version: 0.5
shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
Linux agpgart interface v0.101 (c) Dave Jones
agpgart: Detected an Intel i845 Chipset.
agpgart: AGP aperture is 64M @ 0xe0000000
intel_rng: FWH not detected
input: PC Speaker as /class/input/input1
ACPI: PCI Interrupt 0000:00:1f.3
-> GSI 17 (level, low) -> IRQ 185
input: ImPS/2 Generic Wheel Mouse as /class/input/input2
Linux video capture interface: v2.00
ts: Compaq touchscreen protocol output
bttv: driver version 0.9.16 loaded
bttv: Bt8xx card found (0).
ACPI: PCI Interrupt 0000:03:0c.0[A] -> GSI 22 (level, low) -> IRQ 193
bttv0: Bt878 (rev 17) at 0000:03:0c.0, irq: 193, latency: 32, mmio: 0xdf5fe000
bttv0: using: Kodicom 4400R (slave) [card=133,insmod option]
bttv0: using tuner=4
bttv0: registered device video0
bttv0: registered device vbi0
bttv: Bt8xx card found (1).
ACPI: PCI Interrupt 0000:03:0d.0[A] -> GSI 16 (level, low) -> IRQ 201
bttv1: Bt878 (rev 17) at 0000:03:0d.0, irq: 201, latency: 32, mmio: 0xdf5fc000
bttv1: using: Kodicom 4400R (master) [card=132,insmod option]
floppy0: no floppy controllers found
bttv1: using tuner=4
bttv1: registered device video1
bttv1: registered device vbi1
bttv: Bt8xx card found (2).
ACPI: PCI Interrupt 0000:03:0e.0[A] -> GSI 18 (level, low) -> IRQ 209
bttv2: Bt878 (rev 17) at 0000:03:0e.0, irq: 209, latency: 32, mmio: 0xdf5fa000
bttv2: using: Kodicom 4400R (slave) [card=133,insmod option]
Adding 1028152k swap on /dev/hda3. Priority:-1 extents:1 across:1028152k
EXT3 FS on hda1, internal journal
bttv2: using tuner=4
bttv2: registered device video2
bttv2: registered device vbi2
bttv: Bt8xx card found (3).
ACPI: PCI Interrupt 0000:03:0f.0[A] -> GSI 21 (level, low) -> IRQ 217
bttv3: Bt878 (rev 17) at 0000:03:0f.0, irq: 217, latency: 32, mmio: 0xdf5f8000
bttv3: using: Kodicom 4400R (slave) [card=133,insmod option]
bttv3: using tuner=4
bttv3: registered device video3
bttv3: registered device vbi3
EXT3 FS on hda5, internal journal
e100: eth0: e100_watchdog: link up, 100Mbps, full-duplex
Netfilter messages via NETLINK v0.30.
ip_conntrack version 2.4 (4095 buckets, 32760 max) - 224 bytes per conntrack
ip_tables: (C) 2000-2006 Netfilter Core Team
Warning: /proc/ide/hd?/settings interface is obsolete, and will be removed soon!
NET: Registered protocol family 10
lo: Disabled Privacy Extensions
IPv6 over IPv4 tunneling driver
eth0: no IPv6 routers present
THAT is before start zoneminder, then when i start it, dmesg shows:
bttv2: OCERR @ 1fbf3000,bits: HSYNC FBUS FDSR OCERR*
bttv2: OCERR @ 1fbf3000,bits: HSYNC FDSR OCERR*
success
/***LOOK AT THE COMMAND PROMPT BELOW THIS LINE***/
carmelo:~# bttv2: OCERR @ 1fbf3000,bits: HSYNC FBUS FDSR OCERR*
bttv1: OCERR @ 1f9b901c,bits: HSYNC RISCI* FDSR OCERR*
bttv1: OCERR @ 1f9b9000,bits: HSYNC OCERR*
bttv2: OCERR @ 1fbf301c,bits: HSYNC FDSR OCERR*
bttv2: OCERR @ 1fbf301c,bits: HSYNC RISCI* FBUS FDSR OCERR*
bttv2: OCERR @ 1fbf3014,bits: HSYNC FBUS FDSR OCERR*
bttv2: OCERR @ 1fbf3014,bits: HSYNC FDSR OCERR*
bttv2: OCERR @ 1fbf301c,bits: HSYNC RISCI* FDSR OCERR*
bttv2: SCERR @ 1fbf3000,bits: VSYNC* HSYNC FBUS FTRGT FDSR SCERR*
bttv2: SCERR @ 1fbf3000,bits: VSYNC* HSYNC FBUS SCERR*
bttv2: IRQ lockup, cleared int mask [bits: VSYNC* HSYNC FBUS SCERR*]
bttv2: OCERR @ 1fbf3000,bits: VSYNC HSYNC FBUS FDSR OCERR*
bttv2: OCERR @ 1fbf3014,bits: VSYNC HSYNC FBUS FDSR OCERR*
bttv3: OCERR @ 1fe9c000,bits: HSYNC FBUS FDSR OCERR*
bttv2: OCERR @ 1fbf301c,bits: HSYNC FBUS FDSR OCERR*
BUG: unable to handle kernel NULL pointer dereference at virtual address 00000007
printing eip:
c014a589
*pde = 00000000
Oops: 0002 [#1]
SMP
Modules linked in: ipv6 ip_nat_irc ip_nat_ftp ip_conntrack_irc ip_conntrack_ftp ipt_LOG iptable_mangle iptable_filter iptable_nat ip_nat ip_tables ip_conntrnCPU: 0
EIP: 0060:[<c014a589>] Not tainted VLI
EFLAGS: 00210282 (2.6.18-4-686 #1)
EIP is at page_address+0x0/0x81
eax: c111c9e0 ebx: 00000007 ecx: 00000007 edx: 08e4f067
esi: 00000007 edi: b332f000 ebp: c111c9ec esp: cc9a3bec
ds: 007b es: 007b ss: 0068
Process zmc (pid: 3036, ti=cc9a2000 task=cc996aa0 task.ti=cc9a2000)
Stack: c014b495 b332f000 cc998e48 b332f000 00000007 cc998e48 b332f000 00000000
c014c82d df5e5200 cc996aa0 00000030 00000022 00000000 dd8dd000 fffffff4
cca9a8e4 b332f000 00000000 e0968277 00000208 00000001 00000001 dd8dd000
Call Trace:
[<c014b495>] follow_page+0x4e/0x130
[<c014c82d>] get_user_pages+0x207/0x259
[<e0968277>] videobuf_dma_init_user+0xcf/0x128 [video_buf]
[<e0968544>] videobuf_iolock+0x71/0xbc [video_buf]
[<e0995d3c>] bttv_prepare_buffer+0x102/0x143 [bttv]
[<e0998527>] bttv_do_ioctl+0x9c7/0x1b7c [bttv]
[<c0116412>] __activate_task+0x1c/0x29
[<c011624d>] __wake_up_common+0x2f/0x53
[<c011669e>] __wake_up+0x2a/0x3d
[<e0996466>] bttv_irq_wakeup_video+0x138/0x140 [bttv]
[<e0997082>] bttv_irq+0x4f1/0x694 [bttv]
[<c013fb57>] handle_IRQ_event+0x23/0x49
[<c0112613>] end_level_ioapic_vector+0x14/0x7d
[<c013fc54>] __do_IRQ+0xd7/0xe8
[<c016d7fe>] __d_lookup+0x98/0xdb
[<c0165328>] do_lookup+0x4f/0x135
[<c016db74>] dput+0x1a/0x11b
[<c01672c4>] __link_path_walk+0xbe4/0xd1d
[<c017122a>] mntput_no_expire+0x11/0x6a
[<c01674b0>] link_path_walk+0xb3/0xbd
[<e091b649>] video_usercopy+0x175/0x23b [videodev]
[<c012522e>] do_timer+0x79f/0x8d2
[<e0995e4a>] bttv_ioctl+0x31/0x35 [bttv]
[<e0997b60>] bttv_do_ioctl+0x0/0x1b7c [bttv]
[<c0169273>] do_ioctl+0x47/0x5d
[<c01694d3>] vfs_ioctl+0x24a/0x25c
[<c016952d>] sys_ioctl+0x48/0x5f
[<c0102c7b>] syscall_call+0x7/0xb
Code: 03 00 0a 00 00 17 03 00 1b 04 00 14 00 00 18 01 00 19 01 00 19 01 00 19 01 00 19 01 00 19 01 00 19 01 00 19 01 00 19 01 00 19 01 <00> 19 01 00 1b 03 0
EIP: [<c014a589>] page_address+0x0/0x81 SS:ESP 0068:cc9a3bec
<1>BUG: unable to handle kernel paging request at virtual address fff726df
printing eip:
c014a591
*pde = 00004067
*pte = 00000000
Oops: 0002 [#2]
SMP
EIP: 0060:[<c014a591>] Not tainted VLI
EFLAGS: 00210202 (2.6.18-4-686 #1)
EIP is at page_address+0x8/0x81
eax: fff726df ebx: cc9a3b20 ecx: df5e5200 edx: c137678c
esi: 08048000 edi: df5e5200 ebp: cc9a3b5c esp: cc9a3ab8
Stack: c014b9c2 00000000 cc99d80c cc9a3b20 00000000 00000001 0807a000 c950f080
df5e5200 c14040a0 c0125545 cc9a3ae4 c137678c c950f080 00400000 0807a000
00000000 cc9a3b20 cc99d80c df5e5200 cc9a3b5c c014de31 ffffffff cc9a3b1c
Call Trace:
[<c014b9c2>] unmap_vmas+0x44b/0x4af
[<c0125545>] run_timer_softirq+0x39/0x151
[<c014de31>] exit_mmap+0x6a/0xd7
[<c011b217>] mmput+0x20/0x76
[<c011fa05>] do_exit+0x193/0x71b
[<c0103f9f>] die+0x1e2/0x28a
[<c0104022>] die+0x265/0x28a
[<c01156e0>] do_page_fault+0x3b4/0x481
[<c0145841>] __alloc_pages+0x4e/0x275
[<c011532c>] do_page_fault+0x0/0x481
[<c01037f9>] error_code+0x39/0x40
Code: 1b 04 00 14 00 00 18 01 00 19 01 00 19 01 00 19 01 00 19 01 00 19 01 00 19 01 00 19 01 00 19 01 00 19 01 00 19 01 00 1b 03 00 19 <01> 00 1a 02 00 19 0
EIP: [<c014a591>] page_address+0x8/0x81 SS:ESP 0068:cc9a3ab8
<1>Fixing recursive fault but reboot is needed!
BUG: unable to handle kernel NULL pointer dereference at virtual address 00000000
printing eip:
c014a589
*pde = 00000000
Oops: 0002 [#3]
SMP
EFLAGS: 00210287 (2.6.18-4-686 #1)
eax: c13c6300 ebx: c13c6300 ecx: 00000000 edx: c02cd540
esi: 00000000 edi: 00000000 ebp: c02cd540 esp: c5bd9c64
Process zmc (pid: 3009, ti=c5bd8000 task=c5f2c550 task.ti=c5bd8000)
Stack: c0145273 dffa8048 dffa8000 cca9a178 e09b40cc e08e93d3 1e318000 cca9a0e4
cca9a0c0 dca15610 e099d2f6 dca15610 cca9a0c0 00000000 e09b40cc e09985e4
cca9a1c0 dca15600 00000000 00200086 dffa61c0 e0864014 c14048a0 dca15610
Call Trace:
[<c0145273>] free_hot_cold_page+0x92/0xfa
[<e08e93d3>] btcx_riscmem_free+0x4b/0x59 [btcx_risc]
[<e099d2f6>] bttv_dma_free+0x4e/0x68 [bttv]
[<e09985e4>] bttv_do_ioctl+0xa84/0x1b7c [bttv]
[<c011776e>] try_to_wake_up+0x355/0x35f
[<c0124a81>] process_timeout+0x0/0x5
[<c0125634>] run_timer_softirq+0x128/0x151
[<c0103747>] apic_timer_interrupt+0x1f/0x24
[<c027fc12>] schedule+0x84e/0x8fe
EIP: [<c014a589>] page_address+0x0/0x81 SS:ESP 0068:c5bd9c64
<1>BUG: unable to handle kernel paging request at virtual address ffcb38ff
printing eip:
c014a591
*pde = 00004067
*pte = 00000000
Oops: 0002 [#4]
SMP
EFLAGS: 00210286 (2.6.18-4-686 #1)
eax: ffcb38ff ebx: c5bd9b98 ecx: c5441e40 edx: c10b79ac
esi: 08048000 edi: c5441e40 ebp: c5bd9bd4 esp: c5bd9b30
Stack: c014b9c2 00000000 c5bcc2cc c5bd9b98 00000000 00000001 0807a000 c5442080
c5441e40 c14040a0 c0125545 c5bd9b5c c10b79ac c5442080 00400000 0807a000
00000000 c5bd9b98 c5bcc2cc c5441e40 c5bd9bd4 c014de31 ffffffff c5bd9b94
Call Trace:
EIP: [<c014a591>] page_address+0x8/0x81 SS:ESP 0068:c5bd9b30
printing eip:
c014a589
*pde = 00000000
Oops: 0002 [#5]
SMP
eax: c13d90c0 ebx: c13d90c0 ecx: 00000000 edx: c02cd540
esi: 00000000 edi: de31f448 ebp: 00001000 esp: c5c19ce0
Process zma (pid: 3006, ti=c5c18000 task=cc996000 task.ti=c5c18000)
Stack: c015bb1c de31f448 de31f448 fffff000 c015bbd9 00000001 c13d90c0 fffff000
c13d90c0 dd02ce9c 00000000 00000000 c015bc30 c13d90c0 dd02ce9c c13d90c0
c015c7ab 0000036c 00000000 c13d90c0 dd02ce9c cc996000 e08bcdc9 00001000
Call Trace:
[<c015bb1c>] set_bh_page+0x43/0x4c
[<c015bbd9>] alloc_page_buffers+0x75/0xbb
[<c015bc30>] create_empty_buffers+0x11/0x7d
[<c015c7ab>] __block_prepare_write+0x82/0x428
[<e08bcdc9>] start_this_handle+0x2bb/0x318 [jbd]
[<e08bc67c>] journal_stop+0x1b0/0x1ba [jbd]
[<c015cb67>] block_prepare_write+0x16/0x23
[<e08f250d>] ext3_get_block+0x0/0xbd [ext3]
[<e08f38ad>] ext3_prepare_write+0x92/0x147 [ext3]
[<c0142b9c>] generic_file_buffered_write+0x241/0x5ea
[<e08f14cf>] __ext3_get_inode_loc+0x109/0x2b9 [ext3]
[<e08f85b3>] __ext3_journal_stop+0x19/0x34 [ext3]
[<c0143301>] __generic_file_aio_write_nolock+0x3bc/0x409
[<c01433a5>] generic_file_aio_write+0x57/0xaa
[<e08efe6d>] ext3_file_write+0x19/0x83 [ext3]
[<c0159d22>] do_sync_write+0xb6/0xf1
[<c012d92d>] autoremove_wake_function+0x0/0x2d
[<c013013c>] hrtimer_run_queues+0xcf/0x157
[<c0105f36>] timer_interrupt+0x69/0x73
[<c0159c6c>] do_sync_write+0x0/0xf1
[<c015a5db>] vfs_write+0xa1/0x143
[<c015abcb>] sys_write+0x3c/0x63
EIP: [<c014a589>] page_address+0x0/0x81 SS:ESP 0068:c5c19ce0
<1>BUG: unable to handle kernel paging request at virtual address ffcb405f
printing eip:
c014a591
*pde = 00004067
*pte = 00000000
Oops: 0002 [#6]
SMP
eax: ffcb405f ebx: c5c19c14 ecx: df1a2ac0 edx: c10b810c
esi: 08048000 edi: df1a2ac0 ebp: c5c19c50 esp: c5c19bac
Stack: c014b9c2 00000000 c5c09df4 c5c19c14 00000000 00000001 08079000 c5c78080
df1a2ac0 c14040a0 c022a853 0000012c c10b810c c5c78080 00400000 08079000
00000000 c5c19c14 c5c09df4 df1a2ac0 c5c19c50 c014de31 ffffffff c5c19c10
Call Trace:
[<c022a853>] net_rx_action+0x92/0x17f
EIP: [<c014a591>] page_address+0x8/0x81 SS:ESP 0068:c5c19bac
BUG: unable to handle kernel NULL pointer dereference at virtual address 00000001
printing eip:
c014a589
*pde = 00000000
Oops: 0002 [#7]
SMP
EFLAGS: 00010046 (2.6.18-4-686 #1)
eax: c13d90e0 ebx: c13d90e0 ecx: 00000001 edx: 00000001
esi: 00000001 edi: dfb959c0 ebp: dfb959c0 esp: db1c59bc
Process zmdc.pl (pid: 2969, ti=db1c4000 task=db13faa0 task.ti=db1c4000)
Stack: c015749f 00000000 00000000 00000020 dfb98cc0 dfb8e600 00000000 00000000
00000040 00000000 00000020 00000000 00000003 000eed66 00000002 dfb98cc0
0000000e dfedfc98 c01571c8 df0abaa0 00000020 c0126400 0000000e 00000001
Call Trace:
[<c015749f>] cache_alloc_refill+0x2ce/0x44e
[<c01571c8>] kmem_cache_alloc+0x32/0x3b
[<c0126400>] __sigqueue_alloc+0x37/0x69
[<c0126469>] send_signal+0x37/0xe5
[<c0126934>] __group_send_sig_info+0x64/0x7e
[<c0126fac>] group_send_sig_info+0x39/0x56
[<c01274dd>] send_group_sig_info+0x1e/0x29
[<c0120c95>] it_real_fn+0x19/0x49
[<c0120c7c>] it_real_fn+0x0/0x49
[<c0130170>] hrtimer_run_queues+0x103/0x157
[<c0125530>] run_timer_softirq+0x24/0x151
[<c0121838>] __do_softirq+0x5a/0xbb
[<c01218cf>] do_softirq+0x36/0x3a
[<c027fc44>] schedule+0x880/0x8fe
[<c0125380>] lock_timer_base+0x15/0x2f
[<c0125491>] __mod_timer+0x99/0xa3
[<c0280388>] schedule_timeout+0x71/0x8c
[<c016a0c5>] do_select+0x37a/0x3d4
[<c016a627>] __pollwait+0x0/0xb2
[<c0117778>] default_wake_function+0x0/0xc
[<c014170b>] find_get_page+0x18/0x38
[<c015bacf>] __find_get_block_slow+0xfb/0x105
[<c015bdf8>] __find_get_block+0x15c/0x166
[<c015be29>] __getblk+0x27/0x266
[<c022359a>] sock_def_readable+0x31/0x5b
[<c02758e3>] unix_dgram_sendmsg+0x3e8/0x474
[<c021fec7>] sock_sendmsg+0xce/0xe8
[<c016a3ab>] core_sys_select+0x28c/0x2a9
[<c016a971>] sys_select+0x9f/0x182
EIP: [<c014a589>] page_address+0x0/0x81 SS:ESP 0068:db1c59bc
<0>Kernel panic - not syncing: Fatal exception in interrupt
as you can see, it's tricky to see the "success" from the startup script, so i was waiting for it (despite the box already displayed it), and a minute later, another panic, but this time new information appeared: call trace.
i used modconf for the bttv module, these are the parameters i pass to it:
card=133,132,133,133 radio=0,0,0,0 pll=28,28,28,28 tuner=4,4,4,4 autoload=1 gbuffers=32 bttv_verbose=0 bttv_debug=0 irq_debug=0
AND the dmesg after starting zoneminder: the same as above but with the ugly OCERR
Linux version 2.6.18-4-686 (Debian 2.6.18.dfsg.1-11) (waldi@debian.org) (gcc version 4.1.2 20061115 (prerelease) (Debian 4.1.1-21)) #1 SMP Wed Feb 21 16:06:54 UTC 2007
DMI 2.3 present.
Detected 2399.708 MHz processor.
Initializing CPU#0
Calibrating delay using timer specific routine.. 4803.28 BogoMIPS (lpj=9606564)
CPU: L2 cache: 512K
Brought up 1 CPUs
migration_cost=0
pnp: PnP ACPI init
TCP reno registered
audit(1173358216.464:1): initialized
TCP bic registered
S0 S1 S3 S4 S5)
EXT3-fs: INFO: recovery required on readonly filesystem.
EXT3-fs: write access will be enabled during recovery.
EXT3-fs: hda1: orphan cleanup on readonly fs
ext3_orphan_cleanup: deleting unreferenced inode 779416
ext3_orphan_cleanup: deleting unreferenced inode 779415
ext3_orphan_cleanup: deleting unreferenced inode 779414
ext3_orphan_cleanup: deleting unreferenced inode 779401
ext3_orphan_cleanup: deleting unreferenced inode 779397
EXT3-fs: hda1: 5 orphan inodes deleted
EXT3-fs: recovery complete.
ACPI: PCI Interrupt 0000:00:1f.3 -> GSI 17 (level, low) -> IRQ 185
ADDRCONF(NETDEV_UP): eth0: link is not ready
ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
bttv2: OCERR @ 1e1be000,bits: HSYNC FDSR OCERR*
bttv2: OCERR @ 1e1be000,bits: HSYNC FBUS FDSR OCERR*
bttv2: OCERR @ 1e1be014,bits: HSYNC FBUS FDSR OCERR*
bttv2: OCERR @ 1e1be014,bits: HSYNC FDSR OCERR*
oh, by the way, the bcm43xx isn't installed in the box anymore. just in case it seems as a clue.
thanks for your help
