Aviosys IP Kamera 9060 Working
Posted: Sat Aug 19, 2006 9:48 am
I had been playing around with Zone Minder for a few days now, but unfortunately the only camera hardware I currently have is the Aviosys IP Kamera 9060.
I got it to work with the Perl script that captures jpeg images, and then letting zone minder open it from a local path. Unfortunately this was a little slow, and also took up quite a lot of my (slow pc's) CPU.
At last, I found a way to get the streaming output of the camera into ZoneMinder:
Download the relay file for the NC 800 here: http://www.lavrsen.dk/twiki/bin/view/Mo ... NC800Relay
(This works fine with the 9060 too).
At a linux prompt, type:
cd /usr/src
mkdir relay
cd relay
wget http://www.lavrsen.dk/twiki/pub/Motion/ ... 800.tar.gz
untar -zxvf relay-nc800.tar.gz
make all
The executable will be built now. If you're running a linux distro (like the CTU FC-3 one), where you can't build this file, build it on another pc, or reply to this post, and I'll post the one already compiled for i386.
Now, all you need to do, is run:
./relay-nc800 -url=http://192.168.1.2:8080/cgi-bin/Stream?Video -port=15000
Where 192.168.1.2:8080 is the IP and port of your IP Kamera. (Normally the port is 80).
You can leave the value of 15000 as is for now.
Now go into Zone Minder's config, and add a remote device:
Remote Host Name: 127.0.0.1
Remote Host Port: 15000
Remote Host Path:
(leave remote host path blank).
That's it!!
If you'd like the relay program to auto start when you're starting your pc, put this command in your /etc/rc.local file
nohup /usr/src/relay-nc800 -url=http://192.168.3.84:80/cgi-bin/Stream?Video -port=15000 &
Hope this works as beautifully for you guys as it did for me.
-Christiaan
cd /usr/src
mkdir relay
cd relay
make all
Remote Host Path:
That's it!!
-Christiaan
