Raw stream viewer
nextime
Post by nextime »
Yes, i'm sure that all palettes are right.
It seem to be an issue with the video driver, the videocard it's a crappy nvidia with proprietary driver.
Using the non-gl version of xlib_shm with the -s option solve the problem and i can see good images on video.
wisekki
Post by wisekki »
Are there going to be a working version for ZM 1.23 perhaps?
I'm just asking because this is a very cool user contribution for ZM.
- wisekki
maciekc
Post by maciekc »
wisekki wrote:Are there going to be a working version for ZM 1.23 perhaps?
- wisekki
You just need to specify correct shm_key in command line - -k SHM_KEY.
It will work.
wisekki
Post by wisekki »
Nice, thnx man :)
it works just fine.. didn't even realize that the shared memory key was changed :idea:
linuxsense
Post by linuxsense »
Hmm...I wonder if this could be turned into a plasmoid for KDE4?
lukav
Version 1.23.3
Post by lukav »
I've try everything and I keep getting:
ERROR: Failed to shmget
ENOENT - segment doesn't exist
xlib_shm -w 1024 -h 768 -m 10 -k 0x7a6d2000
I've set the key and run as root.
ZM is running as www-data. I've run xlib_shm as www-data and still no luck
Please help
maciekc
Re: Version 1.23.3
Post by maciekc »
lukav wrote:Hi,
Please help
Please post shm segmnts that exist:
cat /proc/sysvipc/shm
lukav
Re: Version 1.23.3
Post by lukav »
maciekc wrote:Please post shm segmnts that exist:
       key      shmid perms       size  cpid  lpid nattch   uid   gid  cuid  cgid      atime      dtime      ctime
2053963786          0   700   36865188  3261  3291      2    33    33    33    33 1211026726 1211026726 1210932051
2053963787      32769   700   36865188  3267  3291      1    33    33    33    33 1211026726 1211026726 1210932051
2053963788      65538   700   36865188  3273  3291      2    33    33    33    33 1211026726 1211026726 1210932052
2053963789      98307   700   36865188  3279  3291      2    33    33    33    33 1211026726 1211026726 1210932052
         0     163844  1600     393216  3456  3351      2   103   109   103   109 1210932094          0 1210932094
maciekc
Re: Version 1.23.3
Post by maciekc »
Looks like your shm key is 7A6D0000
Try:
xlib_shm -w 1024 -h 768 -m 10 -k 0x7a6d0000
lukav
Re: Version 1.23.3
Post by lukav »
maciekc wrote: Looks like your shm key is 7A6D0000
Try:
Thanks, I should have payed more attention. I've recheck the zm settings the key there is clearly the one you have suggested.
And it works.
Thanks a lot!
Sorry about that.
linuxsense
Anyone ever compile this for a 64bit Ubuntu system?
I seem to be missing the libmysqlclient libs in lib32 to run the 32bit version....
maciekc
Post by maciekc »
linuxsense wrote:Anyone ever compile this for a 64bit Ubuntu system?
I've been using it on 64bit debian. It should also work on ubuntu.
linuxsense
Do you mean you are running the 32bit version on 64bit debian or you were successful in compiling it on a 64bit system?
When I ldd the 32bit version it shows libmysqlclient.so.15 as missing in /usr/lib32 and I could not find a deb to provide it...
maciekc
Post by maciekc »
linuxsense wrote: Do you mean you are running the 32bit version on 64bit debian or you were successful in compiling it on a 64bit system?
I've compiled the 64bit version without any problems.
linuxsense
Thanks, it compiled just fine for me.
