Debian installation Manual (New release)
Is this a good manual ?
Yes, thank you
9
43%
No, its rubbish
2
10%
Yes, but with a few additions
4
19%
Yes, i used it and it worked
1
5%
No, i used it ans it did not work
5
24%
Total votes: 21
R2D2
Post by R2D2 »
Curious if anyone has tested this doc?
Yes i have, the result i´ve posted here:
http://www.zoneminder.com/forums/viewtopic.php?t=5438
Oli
libavcodec2
Post by Oli »
I have followed the instructions in the manual but hit a problem when I enter
apt-get install zm
it tells me I have a broken package - libavcodec2
I am new to linux and can't find this file anywhere else
Thanks in advance,
Oli
ducknet
did not work for me
Post by ducknet »
hi folks i try to do the installation on my sarge installation of debian and it really did`nt work gave problem finish with
e:broken package
sixgun
Re: libavcodec2
Post by sixgun »
Oli wrote:Hi,
apt-get install zm
Thanks in advance,
Oli
I downloaded from here http://ftp.ubuntulinux.org/ubuntu/pool/ ... /f/ffmpeg/ and used dpkg to install it (and for libavcodec2).
dpkg -i ffmpeg_0.4.9-pre1-0.2_i386.deb
dpkg -i libavcodec2_0.4.9-pre1-0.2_i386.deb
or whatever is relevant for your machine.
It all seemed to install ok after that.
Hope that helps.
By the way i am newish to linux, been messing with it on and off for years, but this is the first time i've really tried to use it in anger.
tobkron
Koenzie Debian manual - I'm stuck (Debian stable: 2.6.8-2-38
Post by tobkron »
I'm stuck at step 2 (page 7):
edit - /etc/apt/sources.list
since I do not understand the following lines:
Copy the XS4ALL deb line and change stable into sarge (press ESC and x to delete)
(press ESC and yy to copy, ESC and o to add an new line and ESC p to past)
Copy the XS4ALL line again and change stable into etch
In my file, I don't have these lines. Do I have to insert these from somewhere ?
Here is what I have in my file:
#deb file:///cdrom/ sarge main
deb ftp://ftp3.nrc.ca/debian/ stable main non-free contrib
deb-src ftp://ftp3.nrc.ca/debian/ stable main non-free contrib
deb http://security.debian.org/ stable/updates main contrib non-free
deb ftp://ftp.nerim.net/debian-marillat/ experimental main
deb ftp://ftp.nerim.net/debian-marillat/ sarge main
deb http://www.spic.net/zoneminder/debian/ ./
deb-src http://www.spic.net/zoneminder/debian/ ./
Is that sufficent ?
Thank's for your help
stackbit
Criticism...
Post by stackbit »
Some well -meant criticism:
1 - .doc? Why not a html version? It's just a "save as" in openoffice. There are people installing this in bare-bones instalations with lynx as the browser.
2 - Lacks instructions on putting mpeg to work on debian. (i don't know how to)
3 - Any news on a 1.22 version on debian yet?
Thx for your work.
aife
jameswilson
Post by jameswilson »
can someone edit the link to my mirror as things have chnaged somewhat needs to be www.jpwilson.eu blah blah
James Wilson
zoneminder
Site Admin
Post by zoneminder »
Done. I think.
Phil
theenglishman
Re: Koenzie Debian manual - I'm stuck (Debian stable: 2.6.8-
Post by theenglishman »
tobkron wrote:Hello,
Is that sufficent ?
I've the same problem with Debian Sarge. Can anyone offer any help as I'm completely stuck.
intelio
Re: Debian installation Manual (New release)
Post by intelio »
Koenzie wrote:Hello Everybody,
If somebody else can host it on their server, please do so and post the link
Koenzie
PDF copy located at http://www.intelio.org/downloads/download.php?id=3
whocares
Overlooked
Post by whocares »
I didnt see this until now, but this post might be interesting for this thread
http://www.zoneminder.com/forums/viewto ... 7277#27277
/dave
hcx
Zoneminder Installation Manual
Post by hcx »
Hi Koenzie,
Many thanks for your Manual. Ie installed and configured zoneminder on my Debian machine as described but with username and password admin I cnnot login. Do you know in which file the Password for zoneminder index.php
is written?
Greetings
hcx
jameswilson
its not in there, but if you cant login it could other iisues issues such as cookies etc.
D you need to use debian as the zm distros are a lot easier
James Wilson
hcx
Installation Manual
Post by hcx »
Hi koenzi,
Also many thanks for that. I've installed Zoneminder as described and it runs but I cannot login with admin admin. Could you please tell me in wich file I can edit username and password for the web interface?
Best Regards
hcx
whocares
live cd
Post by whocares »
by zm distro, do you mean the live cd of zm? i tried it and had alot of bugs n glitches, wich i dont have in my debian install
a few examples (live cd glitches:
browser crashes alot on most machines (firefox)
dimensions of windows appear 50% of what they should be (browser popups and stuff)
zm forgets to add a camera or craps out when you add one
