Windows Live Viewer..27-11-05 Now Complete Frontend for ZM!!
NotMe
Re:
Post by NotMe » Mon Jun 20, 2011 7:10 pm
I have the same problem for months now. I saved both custom views and it still pops up. How did you fix this???
cdbao wrote:dear james!!
ZM config is okay - almost have images - in this case I turn off the camera,
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.InvalidCastException: Conversion from string "" to type 'Integer' is not valid. ---> System.FormatException: Input string was not in a correct format.
at Microsoft.VisualBasic.CompilerServices.Conversions.ParseDouble(String Value, NumberFormatInfo NumberFormat)
at Microsoft.VisualBasic.CompilerServices.Conversions.ToInteger(String Value)
--- End of inner exception stack trace ---
at ViseonViewer2.dualHead.Timer2_Tick(Object sender, EventArgs e)
at System.Windows.Forms.Timer.OnTick(EventArgs e)
at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000)
CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
ViseonViewer2
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Documents%20and%20Settings/CDBao/Local%20Settings/Apps/2.0/L85P3ML0.LD9/YVB7GADC.JLJ/vise..tion_0a282930b5e4c390_0001.0000_50a11aef0e65b37f/ViseonViewer2.exe
Assembly Version: 8.0.0.0
Win32 Version: 8.0.50727.3053 (netfxsp.050727-3000)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Runtime.Remoting
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
System.Configuration
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
I think maybe .Net framework proplems ...
ragb1
Re: Windows Live Viewer..27-11-05 Now Complete Frontend for
Post by ragb1 » Sun Jun 26, 2011 11:24 am
Hi:
First of all, I would like to thanks to James for this excellent client.
I would like to comment one issue I discovered with the newer versions of ZM. The problem was provoked for the use of the USE_DEEP_STORAGE option. When I activated it, I couldn't visualize the videos in the playback mode with zm4ms, appereantly because the playback mode only works with the old filesystem hierarchy mode.
Probably this is the cause for the problem commented by bumann.
Best Regards, Raúl.
znelbok
Post by znelbok » Tue Apr 17, 2012 11:44 am
New to zoneminder so go easy please.
I have ZM running with a single cam so its working so far.
I installed zm4ms and it asks for a username and password but none of my usernames work.
Does this software detect where the server is becasue there was no prompt to specify the server location.
What password and username do I use or what configuration is needed before I logon as a valid ZM user
The logon screen shows that it is ZM4MS Viewer v2.89b
Also, on your web page (http://www.jpwilson.eu/photo.htm), second line "Current version 2.88 Download here" has no hypertext link to the file to be downloaded.
Mick
BobS0327
Post by BobS0327 » Sun Apr 22, 2012 12:02 pm
I believe the default user name and password are both admin.
joaoafricano
Re: Windows Live Viewer..27-11-05 Now Complete Frontend for ZM!!
Post by joaoafricano » Wed Aug 10, 2016 8:51 pm
Hello, I do not know if this still en development, but I downloaded the application and can not use because as soon as I open the application it asks me for loguin without even having set up anything.
How do I log me and configure the server?
Is there a file or some other place to set up the connection to the server ZM
SteveGilvarry
Post by SteveGilvarry » Thu Aug 11, 2016 1:36 am
Last post by developer was 5 years ago. Probably safe to assume too many changes to zm in that time, including we ripped out an old interfacing method when we put new API in.
Production Zoneminder 1.35.x
More Dev VM's than I care to count.
Users browsing this forum: No registered users and 6 guests
