iPhone - iPCamera software PTZ
Daedilus
Post by Daedilus » Mon Jul 16, 2018 4:32 pm
Hello Everyone. Been a bit of a lurker here and wish to contribute.
For those whom have an old iphone laying around there is a piece of inexpensive software that I use for some mobile IP Cameras.
https://itunes.apple.com/ca/app/ipcamer ... 12928?mt=8
And if you go the webserver on the phone there are a few options like rotate the picture, flip horizontal / vertical, change the stream quality, change the camera from front facing to main camera, lock the focus, white balance and exposure. So now I've made them available through the control schema.
For the Control settings
Control Address: <user>:<password>@<ip address>:80
In the app you can set a username password and it displays its IP address.
Settings you need are
Control Type: FFMPEG
Protocol: IPCAMIOS
Move
Can Move: Check
Can Move Continuous: Check
Pan
Can Pan: Check
Put 0 for all values.
Tilt
Can Tilt: Check
Focus
Can Focus: Check
Can Focus Absolute: Check
White
Can White Balance: Check
Can White Bal. Absolute: Check
Iris
Can Iris: Check
Can Iris Absolute: Check
Presets
Has Presets: Check
Num Presets: 0
Has Home Preset: Check
Script is named IPCAMIOS.pm and is as follows.
For those whom haven't done this before it is placed in the below directory of your ZM server:
/usr/share/perl5/ZoneMinder/Control
# ZoneMinder iPhone Control Protocol Module, $Date: 2018-07-15 00:20:00 +0000 $, $Revision: 0003 $
# Copyright (C) 2001-2008  Philip Coombes
# Modified for iPhone ipcamera for IOS BY PETER ZARGLIS n 2018-06-09 13:45:00
# This module contains the implementation of the iPhone ipcamera for IOS
# control protocol.
package ZoneMinder::Control::IPCAMIOS;
use 5.006;
use strict;
use warnings;
require ZoneMinder::Base;
require ZoneMinder::Control;
# iPhone ipcamera for IOS Protocol
use Time::HiRes qw( usleep );
my $loopfactor=100000;
sub new
	my $class = shift;
	my $id = shift;
    my $logindetails = "";
    bless( $self, $class );
    srand( time() );
    return $self;
our $AUTOLOAD;
sub AUTOLOAD
    my $self = shift;
    my $name = $AUTOLOAD;
    $name =~ s/.*://;
    if ( exists($self->{$name}) )
    return( $self->{$name} );
sub open
    my $self = shift;
    $self->loadMonitor();
    use LWP::UserAgent;
    $self->{ua}->agent( "ZoneMinder Control Agent" );
    $self->{state} = 'open';
sub close
    my $self = shift;
    $self->{state} = 'closed';
sub sendCmd
    my $self = shift;
    my $cmd = shift;
    my $result = undef;
    if ( $res->is_success )
        $result = $res->decoded_content;
    else
    return( $result );
sub getDisplayAttr
    my $self = shift;
    my $param = shift;
    my $cmdget = "parameters?";
    my $resp = $self->sendCmd( $cmdget );
    my @fields = split(',',$resp);
    my $response=$fields[$param];
    my @buffer=split(':',$response);
    my $response2=$buffer[1];
    return ($response2);
sub sleep
# Flip image vertically -> Horz -> off
sub moveConUp
    my $self = shift;
    my $params = shift;
    Debug( "Flip Image" );
    my $dvalue=$self->getDisplayAttr(3);
    if ( $dvalue == 2 )
    $dvalue=0;
    my $cmd = "parameters?flip=$dvalue";
    $self->sendCmd( $cmd );
    else
    $dvalue=$dvalue+1;
# Change camera (front facing or back)
sub moveConDown
   	my $self = shift;
    my $params = shift;
    Debug( "Change Camera" );
    my $dvalue=$self->getDisplayAttr(7);
    if ( $dvalue == 0 )
    my $cmd = "parameters?camera=1";
	else
	my $cmd = "parameters?camera=0";
# Picture Orientation Clockwise
sub moveConRight
	my $self = shift;
	my $params = shift;
	Debug( "Orientation" );
	my $dvalue=$self->getDisplayAttr(10);
	if ( $dvalue == 1 )
	$dvalue=4;
	my $cmd = "parameters?rotation=$dvalue";
	else
	$dvalue=$dvalue-1;
# Picture Orientation Anti-Clockwise
sub moveConLeft
    my $self = shift;
    my $params = shift;
    if ( $dvalue == 4 )
	$dvalue=1;
	else
	$dvalue=$dvalue+1;
# presetHome is used to turn off Torch, unlock Focus, unlock Exposure, unlock white-balance, rotation, image flipping
# Just basically reset all the little variables and set it to medium quality
# Rotation = 0 means it will autoselect using built in detection
sub presetHome
	my $self = shift;
	Debug( "Home Preset" );
	my $cmd = "parameters?torch=0&focus=0&wb=0&exposure=0&rotation=0&flip=0&quality=0.5";
sub focusAbsNear
# Focus Un/Lock
	my $self = shift;
	my $params = shift;
	Debug( "Focus Un/Lock" );
	my $dvalue=$self->getDisplayAttr(2);
	if ( $dvalue == 0 )
	my $cmd = "parameters?focus=1";
	else
	my $cmd = "parameters?focus=0";
sub focusAbsFar
# Exposure Un/Lock
	my $self = shift;
	my $params = shift;
	Debug( "Exposure Un/Lock" );
	my $dvalue=$self->getDisplayAttr(11);
	if ( $dvalue == 0 )
	my $cmd = "parameters?exposure=1";
	else
	my $cmd = "parameters?exposure=0";
# Increase stream Quality (from 0 to 10)
sub irisAbsOpen
	my $self = shift;
	my $params = shift;
	Debug( "Quality" );
	my $dvalue=$self->getDisplayAttr(8);
	if ( $dvalue < 1 )
	$dvalue=$dvalue+0.1;
	my $cmd = "parameters?quality=$dvalue";
# Decrease stream Quality (from 10 to 0)
sub irisAbsClose
	my $self = shift;
	my $params = shift;
	Debug( "Quality" );
	if ( $dvalue > 0 )
	$dvalue=$dvalue-0.1;
# White Balance Un/Lock
sub whiteAbsIn
	my $self = shift;
	my $params = shift;
	Debug( "White Balance" );
	my $dvalue=$self->getDisplayAttr(9);
	if ( $dvalue == 0 )
	my $cmd = "parameters?wb=1";
	else
	my $cmd = "parameters?wb=0";
# Torch control on/off
sub whiteAbsOut
	my $self = shift;
	my $params = shift;
	Debug( "Torch" );
	my $dvalue=$self->getDisplayAttr(5);
	if ( $dvalue == 0 )
	my $cmd = "parameters?torch=1";
	else
	my $cmd = "parameters?torch=0";
1;
Daedilus
Re: iPhone - iPCamera software
Post by Daedilus » Mon Jul 16, 2018 4:41 pm
The controls are as follows
Focus Near: Locks / Unlocks the Focus
Focus Far: Locks / Unlock the Exposure
White In: Locks / Unlocks the White Balance
White Out: Turns the Light(Torch) On/Off
Iris Open: Increase Stream Quality (From 0 to 10 by increments of 1)
Iris Close: Decrease Steam Quality (From 10 to 0 by increments of 1)
Move Up: Flip the Image (Vert -> Horz -> Off)
Move Down: Toggle Main Camera / Secondary Camera
Move Left: Rotate Counter/Anti Clockwise the video
Move Right: Rotate Clockwise the video.
(Note: Doing so will upset the capture width and height you have set in the source tab for the monitor you will have to exchange these values if you wish to keep the setting)
Home button will turn off Torch, unlock Focus, unlock Exposure, unlock white-balance, rotation, image flipping and set the quality to 50%
Hope this works out for everyone
asker
Re: iPhone - iPCamera software PTZ
Post by asker » Mon Jul 16, 2018 11:41 pm
Very nice. Can you please do a PR so its merged into ZoneMinder?
Daedilus
Post by Daedilus » Mon Jul 16, 2018 11:50 pm
Not sure how to do that.
asker
Post by asker » Tue Jul 17, 2018 12:28 am
Daedilus
Post by Daedilus » Tue Jul 17, 2018 2:39 am
I think that's it.
asker
Post by asker » Tue Jul 17, 2018 8:07 pm
Thanks for the PR! I look forward to using it
