Page 1 of 1
Megapixel PTZlF IP Camera
Posted: Sun Apr 22, 2018 3:04 pm
by adamoutler
Hi. This is my first post. I picked up a "LEFTEK Dome Camera Ultra HD 4.0 MP MINI POE PTZ" camera from amazon, here
https://www.amazon.com/gp/product/B077P ... UTF8&psc=1. This PTZ-FI camera costs $149.99. but it wasn't supported by Zoneminder.
I am here to bring support for the following actions:
- Pan
Tilt
Move Diagonally
Move Continuous
Zoom Continuous
Focus Continuous
Iris Continuous
10 Presets (Preset 9 is patrol mode, Preset 10 is stop)
Perl Script:
https://pastebin.adamoutler.com/lSPx
The megapixelcamera class is based on the onvif class. The web-ui running on the camera is called "Megapixel IP Camera", so the naming I chose is based on the title of the software.
Re: Megapixel PTZlF IP Camera
Posted: Sat Jun 02, 2018 6:40 pm
by adamoutler
Link went down. I'm copying it here.
adamoutler@camserver:/usr/share/perl5/ZoneMinder/Control$ cat megapixelcamera.pm
# ZoneMinder megapixel camera Module
# Copyright (C) Jan M. Hochstein
# Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA.
# This module contains the implementation of the ONVIF device control protocol
package ZoneMinder::Control::megapixelcamera;
use 5.006;
use strict;
use warnings;
require ZoneMinder::Control;
our %CamParams = ();
# megapixel ip camera
# On ControlAddress use the format :
# USERNAME:PASSWORD@ADDRESS:port
# eg : admin:admin@10.1.2.1
# zoneminder:zonepass@10.0.100.1:40000
use Time::HiRes qw( usleep );
sub new
my $class = shift;
my $id = shift;
my $logindetails = "";
bless( $self, $class );
srand( time() );
return $self;#
our $AUTOLOAD;
sub AUTOLOAD
my $self = shift;
my $class = ref( ) || croak( "$self not object" );
my $name = $AUTOLOAD;
$name =~ s/.*://;
if ( exists($self->{$name}) )
return( $self->{$name} );
sub open
my $self = shift;
$self->loadMonitor();
use LWP::UserAgent;
$self->{ua}->agent( "ZoneMinder Control Agent/".ZoneMinder::Base::ZM_VERSION );
$self->{state} = 'open';
sub close
my $self = shift;
$self->{state} = 'closed';
sub printMsg
my $self = shift;
my $msg = shift;
my $msg_len = length($msg);
sub sendCmd
my $self = shift;
my $cmd = shift;
my $result = undef;
printMsg( $cmd, "Tx" );
if ( $res->is_success )
$result = !undef;
else
return( $result );
sub getCamParams
my $self = shift;
my $req = HTTP::Request->new( GET=>"http://".$self->{Monitor}->{ControlAddress}."/get_camera_params.cgi" );
# Parse results setting values in %FCParams
my $content = $res->decoded_content;
while ($content =~ s/var\s+([^=]+)=([^;]+);//ms) {
$CamParams{$1} = $2;
else
#autoStop
#This makes use of the ZoneMinder Auto Stop Timeout on the Control Tab
sub autoStop
my $self = shift;
my $stop_command = shift;
my $autostop = shift;
if( $stop_command && $autostop)
Debug( "Auto Stop" );
usleep( $autostop );
my $cmd = "/form/setPTZCfg/?command=0&";#.$stop_command;
$self->sendCmd( $cmd );
# Reset the Camera
sub reset
my $self = shift;
Debug( "Camera Reset" );
my $cmd = "form/reboot?language=en";
#Up Arrow
sub moveConUp
my $self = shift;
my $stop_command = "0";
Debug( "Move Up" );
my $cmd = "/form/setPTZCfg/?command=1";
$self->autoStop( $stop_command, $self->{Monitor}->{AutoStopTimeout} );
#Down Arrow
sub moveConDown
my $self = shift;
Debug( "Move Down" );
my $cmd = "/form/setPTZCfg/?command=2";
#Left Arrow
sub moveConLeft
my $self = shift;
Debug( "Move Left" );
my $cmd = "/form/setPTZCfg/?command=3";
#Right Arrow
sub moveConRight
my $self = shift;
Debug( "Move Right" );
my $cmd = "/form/setPTZCfg/?command=4";
#Zoom In
sub zoomConTele
my $self = shift;
my $stop_command = "17";
Debug( "Zoom Tele" );
my $cmd = "/form/setPTZCfg/?command=18";
#Zoom Out
sub zoomConWide
my $self = shift;
my $stop_command = "19";
Debug( "Zoom Wide" );
my $cmd = "/form/setPTZCfg/?command=16";
#Diagonally Up Right Arrow
#This camera does not have builtin diagonal commands so we emulate them
sub moveConUpRight
my $self = shift;
my $cmd = "/form/setPTZCfg/?command=7";
#Diagonally Down Right Arrow
sub moveConDownRight
my $self = shift;
my $cmd = "/form/setPTZCfg/?command=8";
# $self->moveConDown( );
# $self->moveConRight( );
#Diagonally Up Left Arrow
sub moveConUpLeft
my $self = shift;
my $cmd = "/form/setPTZCfg/?command=6";
# $self->moveConUp( );
# $self->moveConLeft( );
#Diagonally Down Left Arrow
sub moveConDownLeft
my $self = shift;
my $cmd = "/form/setPTZCfg/?command=5";
#Stop
sub moveStop
my $self = shift;
Debug( "Move Stop" );
my $cmd = "/form/setPTZCfg/?command=0";
#Set Camera Preset
#Those values are: 30,32,34,36,38,40,42,44 for presets 1-8 respectively
sub presetSet
my $self = shift;
my $params = shift;
if (( $preset >= 1 ) && ( $preset <= 8 )) {
my $cmd = "/form/presetSet?existFlag=1&flag=3&language=en&presetNum=".$preset;
#Recall Camera Preset
#Those values are: 31,33,35,37,39,41,43,45 for presets 1-8 respectively
sub presetGoto
my $self = shift;
my $params = shift;
my $cmd = "/form/presetSet?existFlag=1&flag=4&language=en&presetNum=".$preset;
if ( $preset == 9 ) {
$self->horizontalPatrol();
if ( $preset == 10 ) {
$self->horizontalPatrolStop();
#Horizontal Patrol - Vertical Patrols are not supported
sub horizontalPatrol
my $self = shift;
Debug( "Horizontal Patrol" );
my $cmd = "/form/setSpecialFunc?command=1&flag=2";
#Horizontal Patrol Stop
sub horizontalPatrolStop
my $self = shift;
Debug( "Horizontal Patrol Stop" );
my $cmd = "/form/setPTZCfg?command=0";
sub irisConOpen
my $self = shift;
Debug( "Iris Continuous Open" );
my $cmd = "/form/setPTZCfg?command=9";
$self->autoStop( "0", $self->{Monitor}->{AutoStopTimeout} );
sub irisStop
my $self = shift;
Debug( "Iris Stop" );
sub irisConOpen
my $self = shift;
Debug( "Iris Continuous Close" );
my $cmd = "/form/setPTZCfg?command=10";
# $self->autoStop( "0", $self->{Monitor}->{AutoStopTimeout} );
sub zoomConTele
my $self = shift;
Debug( "Zoom In Tele Continuous" );
my $cmd = "/form/setPTZCfg?command=13";
sub zoomStop
my $self = shift;
Debug( "Zoom Stop" );
sub zoomConWide
my $self = shift;
Debug( "Zoom Out Wide Continuous" );
my $cmd = "/form/setPTZCfg?command=14";
sub focusConNear
my $self = shift;
my $cmd = "/form/setPTZCfg?command=12";
sub focusStop
my $self = shift;
sub focusConFar
my $self = shift;
my $cmd = "/form/setPTZCfg?command=11";
1;
Posted: Thu Jun 13, 2019 5:41 am
by isak.levinson
Thank you so much for your contribution!
I also have this camera, unfortunately, I couldn't make it move.
Could you please elaborate of what should be in the "Control Address" field?
I tried: admin:admin@192.168.1.50, admin:admin@192.168.1.80, and with some other ports numbers. None of them worked.
Are there any other fields that should be filled? "Control device" or such?
Thanks, Isak.
Posted: Thu Jun 13, 2019 3:55 pm
by adamoutler
The last major update pwned several things. I haven't set it all back up yet.
