Megapixel PTZlF IP Camera
adamoutler
Post by adamoutler » Sun Apr 22, 2018 3:04 pm
Hi. This is my first post. I picked up a "LEFTEK Dome Camera Ultra HD 4.0 MP MINI POE PTZ" camera from amazon, here https://www.amazon.com/gp/product/B077P ... UTF8&psc=1. This PTZ-FI camera costs $149.99. but it wasn't supported by Zoneminder.
I am here to bring support for the following actions:
  • Pan
    Tilt
    Move Diagonally
    Move Continuous
    Zoom Continuous
    Focus Continuous
    Iris Continuous
    10 Presets (Preset 9 is patrol mode, Preset 10 is stop)
Perl Script:
https://pastebin.adamoutler.com/lSPx
The megapixelcamera class is based on the onvif class. The web-ui running on the camera is called "Megapixel IP Camera", so the naming I chose is based on the title of the software.
adamoutler
Re: Megapixel PTZlF IP Camera
Post by adamoutler » Sat Jun 02, 2018 6:40 pm
Link went down. I'm copying it here.
adamoutler@camserver:/usr/share/perl5/ZoneMinder/Control$ cat megapixelcamera.pm
# ZoneMinder megapixel camera Module
# Copyright (C) Jan M. Hochstein
# Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA.
# This module contains the implementation of the ONVIF device control protocol
package ZoneMinder::Control::megapixelcamera;
use 5.006;
use strict;
use warnings;
require ZoneMinder::Control;
our %CamParams = ();
# megapixel ip camera
# On ControlAddress use the format :
#   USERNAME:PASSWORD@ADDRESS:port
#   eg : admin:admin@10.1.2.1
#        zoneminder:zonepass@10.0.100.1:40000
use Time::HiRes qw( usleep );
sub new
    my $class = shift;
    my $id = shift;
    my $logindetails = "";
    bless( $self, $class );
    srand( time() );
    return $self;#
our $AUTOLOAD;
sub AUTOLOAD
    my $self = shift;
    my $class = ref( ) || croak( "$self not object" );
    my $name = $AUTOLOAD;
    $name =~ s/.*://;
    if ( exists($self->{$name}) )
        return( $self->{$name} );
sub open
    my $self = shift;
    $self->loadMonitor();
    use LWP::UserAgent;
    $self->{ua}->agent( "ZoneMinder Control Agent/".ZoneMinder::Base::ZM_VERSION );
    $self->{state} = 'open';
sub close
    my $self = shift;
    $self->{state} = 'closed';
sub printMsg
    my $self = shift;
    my $msg = shift;
    my $msg_len = length($msg);
sub sendCmd
    my $self = shift;
    my $cmd = shift;
    my $result = undef;
    printMsg( $cmd, "Tx" );
    if ( $res->is_success )
        $result = !undef;
    else
    return( $result );
sub getCamParams
    my $self = shift;
    my $req = HTTP::Request->new( GET=>"http://".$self->{Monitor}->{ControlAddress}."/get_camera_params.cgi" );
        # Parse results setting values in %FCParams
        my $content = $res->decoded_content;
        while ($content =~ s/var\s+([^=]+)=([^;]+);//ms) {
            $CamParams{$1} = $2;
    else
#autoStop
#This makes use of the ZoneMinder Auto Stop Timeout on the Control Tab
sub autoStop
    my $self = shift;
    my $stop_command = shift;
    my $autostop = shift;
    if( $stop_command && $autostop)
        Debug( "Auto Stop" );
        usleep( $autostop );
        my $cmd = "/form/setPTZCfg/?command=0&";#.$stop_command;
        $self->sendCmd( $cmd );
# Reset the Camera
sub reset
    my $self = shift;
    Debug( "Camera Reset" );
    my $cmd = "form/reboot?language=en";
#Up Arrow
sub moveConUp
    my $self = shift;
    my $stop_command = "0";
    Debug( "Move Up" );
    my $cmd = "/form/setPTZCfg/?command=1";
    $self->autoStop( $stop_command, $self->{Monitor}->{AutoStopTimeout} );
#Down Arrow
sub moveConDown
    my $self = shift;
    Debug( "Move Down" );
    my $cmd = "/form/setPTZCfg/?command=2";
#Left Arrow
sub moveConLeft
    my $self = shift;
    Debug( "Move Left" );
    my $cmd = "/form/setPTZCfg/?command=3";
#Right Arrow
sub moveConRight
    my $self = shift;
    Debug( "Move Right" );
    my $cmd = "/form/setPTZCfg/?command=4";
#Zoom In
sub zoomConTele
    my $self = shift;
    my $stop_command = "17";
    Debug( "Zoom Tele" );
    my $cmd = "/form/setPTZCfg/?command=18";
#Zoom Out
sub zoomConWide
    my $self = shift;
    my $stop_command = "19";
    Debug( "Zoom Wide" );
    my $cmd = "/form/setPTZCfg/?command=16";
#Diagonally Up Right Arrow
#This camera does not have builtin diagonal commands so we emulate them
sub moveConUpRight
    my $self = shift;
    my $cmd = "/form/setPTZCfg/?command=7";
#Diagonally Down Right Arrow
sub moveConDownRight
    my $self = shift;
    my $cmd = "/form/setPTZCfg/?command=8";
#    $self->moveConDown( );
#    $self->moveConRight( );
#Diagonally Up Left Arrow
sub moveConUpLeft
    my $self = shift;
    my $cmd = "/form/setPTZCfg/?command=6";
#    $self->moveConUp( );
#    $self->moveConLeft( );
#Diagonally Down Left Arrow
sub moveConDownLeft
    my $self = shift;
    my $cmd = "/form/setPTZCfg/?command=5";
#Stop
sub moveStop
    my $self = shift;
    Debug( "Move Stop" );
    my $cmd = "/form/setPTZCfg/?command=0";
#Set Camera Preset
#Those values are: 30,32,34,36,38,40,42,44 for presets 1-8 respectively
sub presetSet
    my $self = shift;
    my $params = shift;
    if (( $preset >= 1 ) && ( $preset <= 8 )) {
        my $cmd = "/form/presetSet?existFlag=1&flag=3&language=en&presetNum=".$preset;
#Recall Camera Preset
#Those values are: 31,33,35,37,39,41,43,45 for presets 1-8 respectively
sub presetGoto
    my $self = shift;
    my $params = shift;
        my $cmd = "/form/presetSet?existFlag=1&flag=4&language=en&presetNum=".$preset;
    if ( $preset == 9 ) {
        $self->horizontalPatrol();
    if ( $preset == 10 ) {
        $self->horizontalPatrolStop();
#Horizontal Patrol - Vertical Patrols are not supported
sub horizontalPatrol
    my $self = shift;
    Debug( "Horizontal Patrol" );
    my $cmd = "/form/setSpecialFunc?command=1&flag=2";
#Horizontal Patrol Stop
sub horizontalPatrolStop
    my $self = shift;
    Debug( "Horizontal Patrol Stop" );
    my $cmd = "/form/setPTZCfg?command=0";
sub irisConOpen
    my $self = shift;
    Debug( "Iris Continuous Open" );
    my $cmd = "/form/setPTZCfg?command=9";
    $self->autoStop( "0", $self->{Monitor}->{AutoStopTimeout} );
sub irisStop
    my $self = shift;
    Debug( "Iris Stop" );
sub irisConOpen
    my $self = shift;
    Debug( "Iris Continuous Close" );
    my $cmd = "/form/setPTZCfg?command=10";
#    $self->autoStop( "0", $self->{Monitor}->{AutoStopTimeout} );
sub zoomConTele
    my $self = shift;
    Debug( "Zoom In Tele Continuous" );
    my $cmd = "/form/setPTZCfg?command=13";
sub zoomStop
    my $self = shift;
    Debug( "Zoom Stop" );
sub zoomConWide
    my $self = shift;
    Debug( "Zoom Out Wide Continuous" );
    my $cmd = "/form/setPTZCfg?command=14";
sub focusConNear
    my $self = shift;
    my $cmd = "/form/setPTZCfg?command=12";
sub focusStop
    my $self = shift;
sub focusConFar
    my $self = shift;
    my $cmd = "/form/setPTZCfg?command=11";
1;
isak.levinson
Post by isak.levinson » Thu Jun 13, 2019 5:41 am
Thank you so much for your contribution!
I also have this camera, unfortunately, I couldn't make it move.
Could you please elaborate of what should be in the "Control Address" field?
I tried: admin:admin@192.168.1.50, admin:admin@192.168.1.80, and with some other ports numbers. None of them worked.
Are there any other fields that should be filled? "Control device" or such?
Thanks, Isak.
adamoutler
Post by adamoutler » Thu Jun 13, 2019 3:55 pm
The last major update pwned several things. I haven't set it all back up yet.
