Wanscam HW0045 Control Module
lselinger
Post by lselinger » Tue Nov 28, 2017 3:53 pm
Apologies for double post (perhaps a mod can remove the one from the 1.30.x discussion)
This was a quick kick at the can to get the PTZ portion of my WansCam HW0045 outdoor camera working. Credit in comments to others' work I used. It's pretty much a verbatim copy of a couple other modules with the commands changed. I'll put more effort into it as time permits to add other features or fix the diagonal movement (currently not working). For now, PTZ is working and so is setting and reading presets (16 on this camera).
# ZoneMinder Wanscam HW0045 IP Control Module, $Date: 2017-11-28$, $Revision: 0001 $
# This control module combines parts from FI8620_Y2k.pm as well
# as (primarily) SPP1802SWPTZ.pm on Nov 28 2017 by Lonny Selinger
# Changes made
#       - Copied SPP1802SWPTZ.pm to WanscamHW0045.pm
#       - modified to control a Wanscam HW0045 Outdoor PTZ Camera
# Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA.
package MyAgent;
use base 'LWP::UserAgent';
package ZoneMinder::Control::WanscamHW0045;
use 5.006;
use strict;
use warnings;
require ZoneMinder::Base;
require ZoneMinder::Control;
 use Time::HiRes qw( usleep );
sub new
        my $class = shift;
        my $id = shift;
        my $logindetails = "";
        bless( $self, $class );
        srand( time() );
        return $self;
our $AUTOLOAD;
sub AUTOLOAD
        my $self = shift;
        my $name = $AUTOLOAD;
        $name =~ s/.*://;
        if ( exists($self->{$name}) )
                return( $self->{$name} );
our $stop_command;
sub open
        my $self = shift;
        $self->loadMonitor();
        $self->{ua} = MyAgent->new;
        $self->{ua}->agent( "ZoneMinder Control Agent/" );
        $self->{state} = 'open';
sub close
        my $self = shift;
        $self->{state} = 'closed';
sub printMsg
        my $self = shift;
        my $msg = shift;
        my $msg_len = length($msg);
sub sendCmd
        my $self = shift;
        my $cmd = shift;
        my $result = undef;
        printMsg( $cmd, "Tx" );
        my $req = HTTP::Request->new( GET=>"http://".$self->{Monitor}->{ControlAddress}."/$cmd"."&".$self->{Monitor}->{ControlDevice});
        print "$req\n";
        if ( $res->is_success )
                $result = !undef;
        else
                Error( "Error really, REALLY check failed:'".$res->status_line()."'" );
                Error ("Cmd:".$cmd);
        return( $result );
sub reset
        my $self = shift;
        Debug( "Camera Reset" );
        my $cmd = "reboot.cgi?";
        $self->sendCmd( $cmd );
#Up Arrow
sub moveConUp
        my $self = shift;
        Debug( "Move Up" );
        my $cmd = "cgi-bin/hi3510/ptzctrl.cgi?-step=0&-act=up";
        $self->autoStop( $self->{Monitor}->{AutoStopTimeout} );
#Down Arrow
sub moveConDown
        my $self = shift;
        Debug( "Move Down" );
        my $cmd = "cgi-bin/hi3510/ptzctrl.cgi?-step=0&-act=down";
#Left Arrow
sub moveConLeft
        my $self = shift;
        Debug( "Move Left" );
        my $cmd = "cgi-bin/hi3510/ptzctrl.cgi?-step=0&-act=left";
#Right Arrow
sub moveConRight
        my $self = shift;
        Debug( "Move Right" );
        my $cmd = "cgi-bin/hi3510/ptzctrl.cgi?-step=0&-act=right";
#Diagonally Up Right Arrow
sub moveConUpRight
        my $self = shift;
        foreach my $dir ("up","right") {
                my $cmd = "cgi-bin/hi3510/ptzctrl.cgi?-step=0&-act=$dir";
#Diagonally Down Right Arrow
sub moveConDownRight
        my $self = shift;
        foreach my $dir ("down","right") {
#Diagonally Up Left Arrow
sub moveConUpLeft
        my $self = shift;
        foreach my $dir ("up","left") {
#Diagonally Down Left Arrow
sub moveConDownLeft
        my $self = shift;
        foreach my $dir ("down","left") {
#Stop
sub moveStop
        my $self = shift;
        Debug( "Move Stop" );
        my $cmd = "cgi-bin/hi3510/ptzctrl.cgi?-step=0&-act=stop";
sub autoStop
        my $self = shift;
        my $autostop = shift;
        if( $autostop ) {
                Debug( "Auto Stop" );
                usleep( $autostop );
#Move Camera to Home Position
sub presetHome
        my $self = shift;
        Debug( "Home Preset" );
        my $cmd = "cgi-bin/hi3510/ptzctrl.cgi?-step=0&-act=home";
#Set preset
sub presetSet
    my $self = shift;
    my $params = shift;
    my $presetCmd = "cgi-bin/hi3510/preset.cgi?-act=set&-status=1&-number=$preset";
    Debug( "Set Preset $preset with cmd $presetCmd" );
    my $cmd = $presetCmd;
#Goto preset
sub presetGoto
    my $self = shift;
    my $params = shift;
    my $presetCmd = "cgi-bin/hi3510/preset.cgi?-act=goto&-status=1&-number=$preset";
#Turn IR on
sub wake
        my $self = shift;
        Debug( "Wake - IR on" );
        my $cmd = "cgi-bin/hi3510/param.cgi?cmd=setinfrared&-infraredstat=open";
#Turn IR off
sub sleep
        my $self = shift;
        Debug( "Sleep - IR off" );
        my $cmd = "cgi-bin/hi3510/param.cgi?cmd=setinfrared&-infraredstat=close";
# Zoom Control "In"
sub zoomConTele
    my $self = shift;
    my $params = shift;
    Debug( "Zoom Tele" );
    my $cmd = "cgi-bin/hi3510/ptzctrl.cgi?-step=0&-act=zoomin";
    my $autostop = $self->getParam( $params, 'autostop', 0 );
    if ( $autostop && $self->{Monitor}->{AutoStopTimeout} )
        usleep( $self->{Monitor}->{AutoStopTimeout} );
# Zoom Control "Out"
sub zoomConWide
    my $self = shift;
    my $params = shift;
    Debug( "Zoom Wide" );
    my $cmd = "cgi-bin/hi3510/ptzctrl.cgi?-step=0&-act=zoomout";
1;
__END__
=head1 WANSCAMHW0045
ZoneMinder::Database - Perl extension for Wanscam HW0045 Outdoor PTZ IP Camera
=head1 SYNOPSIS
Control script for Wanscam HW0045 Outdoor PTZ IP Camera.
=head1 DESCRIPTION
For set up, Select WansCam HW0045 as the Control Type. Leave the Control Device Blank
and in the Control Address, use the format user:pass@camera_ip:port
=head2 EXPORT
None by default.
=head1 SEE ALSO
=head1 AUTHOR
Lonny Selinger, Email: <lt>lonny.selinger(at)gmail(dot)com<gt>
Based on the work mostly in SPP1802SWPTZ.pm and partly from FI8620_Y2k.pm with
credit to their respective contributors.
=head1 COPYRIGHT AND LICENSE
This library is free software; you can redistribute it and/or modify
it under the same terms as Perl itself, either Perl version 5.8.3 or,
at your option, any later version of Perl 5 you may have available.
=cut
