Zoneminder RPM & SRPM for Fedora
BiloxiGeek
Re: Zoneminder RPM & SRPM for Fedora
Post by BiloxiGeek » Thu Feb 20, 2014 1:43 pm
knnniggett wrote: yum list available shows pacakges available from the repos currently configured on you system, but the packages shown at the beginning of this thread don't exist in any repo. That's why they are listed there and won't show up with when you issue that command. You have to click on each link, download them to your local drive, and then install them manually.
Ok, I was thinking those should have been available via the repos. I'll probably slick the machine and reinstall and give this another try later today.
Post by knight-of-ni » Sat Mar 15, 2014 5:00 pm
* BUMP *
Zoneminder 1.27.0 RPM's available for Fedora 19.
Please bear with me as I upgrade to F20 and build an additional set of RPM's.
Post by knight-of-ni » Sun Mar 16, 2014 4:07 pm
* BUMP *
Zoneminder 1.27 RPM's are now available for Fedora 20.
Please read the note regarding gnutls.
kenworth
Post by kenworth » Wed Apr 09, 2014 2:00 pm
The latest set of updates for Fedora 20 appear to have resolved the issue with the gnutls libraries. I am able to run ZM 1.26.5 with the following gnutls packages:
gnutls-dane-3.1.20-4.fc20.x86_64
gnutls-devel-3.1.20-4.fc20.x86_64
gnutls-debuginfo-3.1.20-4.fc20.x86_64
gnutls-3.1.20-4.fc20.x86_64
gnutls-c++-3.1.20-4.fc20.x86_64
Have not tried this with ZM 1.27.
jHeron
Post by jHeron » Thu Apr 10, 2014 8:23 pm
Confirmed on F20_64 with 1.27 RPM, working fine with the latest GNUTLS.
Cheers,
Jon
Post by knight-of-ni » Thu Apr 10, 2014 8:29 pm
jHeron wrote:Confirmed on F20_64 with 1.27 RPM, working fine with the latest GNUTLS.
Cheers,
Jon
Ecellent. Thanks for the feedback guys.
I'll update the documentation shortly.
liderbug
Post by liderbug » Tue May 20, 2014 3:28 pm
function.php needs
"date_default_timezone_set('MST7MDT');"
added to the beginning of the file.
and zmupdate.pl has to be run
Post by knight-of-ni » Tue May 20, 2014 3:33 pm
liderbug wrote:function.php needs
Setting the timezone on your system and running zmupdate.pl is documented in the README file.
Post by knight-of-ni » Sun Aug 24, 2014 4:03 pm
I've moved the download links off my home server to Dropbox.
This should help users from outside the US.
Post by knight-of-ni » Sun Oct 19, 2014 1:57 am
* BUMP *
Zoneminder 1.28.0 has been released.
The new RPM's are available from zmprepo.
http://www.zoneminder.com/wiki/index.ph ... ed_distros
I recommend you continue to use yum-priorities and set the priority of zmrepo to something large like 50.
