Net app to change camera function
BobS0327
Post by BobS0327 »
Below is the Net c# source code to change the function of a specific camera. Prerequisites for using the util are as follows:
1. Open up mySQL port 3306 on your Linux box to the outside world. That is, make mySQL on your Linux box accessible from a remote computer.
2. Make the root mySQL userid capable of logging into the Linux mySQL from a remote workstation.
3. Download and install the .Net mySQL data connector from http://dev.mysql.com/downloads/connector/
Finally here is the code. Note the comment at top of code indicating how to compile the code.
// compile: csc /target:exe /reference:"C:\Progra~2\MySql\MySQLC~1.4\Assemb~1\v4.0\MySQLD~2.dll" Function.cs
using System;
using System.Text;
using MySql.Data.MySqlClient;
using System.IO;
using System.Xml;
namespace ConsoleApplication1
    class Program
        private static string server;
        private static string database;
        private static string uid;
        private static string password;
		private static string monitorname;
        private static string function;
        private static bool bfunctionchanged = true;
		private static bool bmonitorfound = false;
        static int Main(string[] args)
            MySqlTransaction tr = null;
            string connectionString;
            MySqlConnection conn = null;
            String command = "SELECT * FROM Monitors";
            MySqlDataReader reader;
            string[] functions = new string[] { "None", "Monitor", "Modect", "Record", "Mocord", "Nodect"};
				if(args.Length != 2)
				  Console.WriteLine("Program aborting, insufficient arguments on command line\n Example, how to use: {0} MonitorName Function", System.AppDomain.CurrentDomain.FriendlyName);
				  return -1;
				else
				 monitorname = args[0];
				 function = args[1];
            string result = Array.Find(functions, delegate(string s) { return s == function; });
            if (result == null)
                Console.WriteLine("Program aborting, Function {0} is not a valid function (Function names are case sensitive)", function);
                return 0;
            if (ReadXMLFile(ref server, ref database, ref uid, ref password, "ZMMysql.xml") == false)
                Console.WriteLine("Error, Program aborting!!!");
                return 1;
            connectionString = "SERVER=" + server + ";" + "DATABASE=" +
                       database + ";" + "UID=" + uid + ";" + "PASSWORD=" + password + ";";
            MySqlConnection connection = new MySqlConnection(connectionString);
            MySqlCommand cmd = new MySqlCommand(command, connection);
            try
                connection.Open();
                cmd.ExecuteNonQuery();
                reader = cmd.ExecuteReader();
                cmd.CommandType = System.Data.CommandType.Text;
                while (reader.Read() != false)
                    if (monitorname == (string)reader["Name"])
                        Console.WriteLine("Found camera {0}", reader["Name"]);
						bmonitorfound = true;
                        if (function == (string)reader["Function"])
                            Console.WriteLine("Camera {0} is already set to function {1}, program terminating, nothing more to do", reader["Name"], reader["Function"]);
                            connection.Close();
                            return 0;
            catch (MySqlException MySqlError)
               // Console.WriteLine(MySqlError.Message);
			   Console.WriteLine("MySqlError Message: {0}", MySqlError.Message.ToString());
            connection.Close();
			   if(bmonitorfound == false)
			      Console.WriteLine("Camera {0} could not be found (be advised, names are case sensitive), program terminating", monitorname);
			       return -1;
            try
                conn = new MySqlConnection(connectionString);
                conn.Open();
                tr = conn.BeginTransaction();
                MySqlCommand cmd1 = new MySqlCommand();
                cmd1.Connection = conn;
                cmd1.Transaction = tr;
				 string formatString = String.Format("UPDATE Monitors SET Function='{0}' WHERE Name='{1}'" , function,monitorname);
               // cmd1.CommandText = "UPDATE Monitors SET Function='Record' WHERE Name='Front-Porch'";
               cmd1.CommandText = formatString;
			    cmd1.ExecuteNonQuery();
            catch (MySqlException ex)
                try
                    tr.Rollback();
					bfunctionchanged = false;
                catch (MySqlException ex1)
                    Console.WriteLine("Error: {0}", ex1.ToString());
                Console.WriteLine("Error: {0}", ex.ToString());
			if(bfunctionchanged == true)
			Console.WriteLine("Camera: {0} successfully change to {1} function", monitorname, function);
            return 0;
        static bool ReadXMLFile(ref string IPAddress, ref string Database, ref string Userid, ref string Password, string XMLFileName)
            bool bReturn = true;
            FileStream READER = null;
            try
                READER = new FileStream(XMLFileName, FileMode.Open, FileAccess.Read, FileShare.ReadWrite); //Set up the filestream (READER) //
                System.Xml.XmlDocument myZMParms = new System.Xml.XmlDocument();// Set up the XmlDocument (myZMParms) //
                myZMParms.Load(READER); //Load the data from the file into the XmlDocument (myZMParms) //
                System.Xml.XmlNodeList NodeList = myZMParms.GetElementsByTagName("ZMParms"); // Create a list of the nodes in the xml file //
                IPAddress = NodeList[0].FirstChild.ChildNodes[0].InnerText; // mySqlIPAddress //
                Database = NodeList[0].FirstChild.ChildNodes[1].InnerText; // database name //
                Userid = NodeList[0].FirstChild.ChildNodes[2].InnerText; // userid //
                Password = NodeList[0].FirstChild.ChildNodes[3].InnerText; // password //
            catch (IOException ex)
                Console.WriteLine(ex.ToString());
                bReturn = false;
            finally
                if (READER != null)
                    READER.Close();
                    READER.Dispose();
            return bReturn;
The util uses a XML file for parameter inputs such as the ip address of your linux ZM box etc. The name should be ZMMysql.xml and it should look as follows and it should be in the same directory as the util.
<?xml version="1.0"?>
      <ZMParms>
	  <ZM>
	    <mySqlIPAddress>000.000.000.000</mySqlIPAddress>
	    <databasename>zm</databasename>
	    <userid>root</userid>
		 <password>password</password>
	  </ZM>
	</ZMParms>
Inputs to the util are the Camera name which is case sensitive and the function (which is also case sensitive) that the camera should be changed to
Example Front-Porch Record
This example will change the function of the Front-Porch camera to Record if it is not currently recording.
