[GUIDE] How to light on leds when an event occours
craver84
Post by craver84 » Sat Jan 02, 2010 2:20 pm
Hi everybody,
I've edited the Perl script we can find in the FAQ, to light on up to 8 leds when there
is an alarm.
I can't program, but it works for me.
I hope you can help me to make it better!! :D
#!/usr/bin/perl -w
# i build a parallel cable with 8 leds following this guide:
# http://www.epanorama.net/circuits/parallel_output.html#linuxprogramming
# this is the schema to create it http://www.epanorama.net/circuits/lptleds.gif
# the software I use to turn on the led is lptout.
# http://www.epanorama.net/circuits/lptout.c
# well, with LPT port I can control 8 leds, so
# in the DB, in table Monitors, I've added a column (int) called LED.
# In this field I set the position of the led I want to light on.
# 1 for the 1st led, 2 for the 2nd...
# So I've changed the query to select only the monitors that corresponds to a led.
# my idea is to create a string variable containing the binary number I want to sent to the port,
# with lptout I can send only decimal values, so after that I convert it to decimal.
# 00000000  all leds off
# 11111111  all leds on
# 00000001  led 1 on
# 00000101  led 1, 3 on
# 10000101  led 1, 3, 8 on
# I use this function to convert binary to decimal
# $decimale= ord(pack('B8', $binario));
# after that I send the decimal number to the port
# system("sudo ./lptout " . $decimale);
use strict;
use ZoneMinder;
$| = 1;
# the new SQL QUERY
my $sql = "select M.*, max(E.Id) as LastEventId from Monitors as M left join Events as E on M.Id = E.MonitorId where M.Function != 'None' and M.Function != 'Monitor'  and E.Id != '' and LED!='' group by (E.MonitorId) order by LED";
my @monitors;
    push( @monitors, $monitor );
my $binario= "";
my $decimale= 0;
my $prima= "";      # I need this to manipolate _
my $dopo= "";       # _ the sting $binario
my $led= 0;         # I have 1 to 8 leds. I use this variable to set the position of the led I want to light
my $evento= 0;
while( 1 )
	system("sudo ./lptout 0");   # I send to lpt port number 0 to turn off all the leds
	$binario = "00000000";
	$decimale= 0;
	$prima = "";
	$dopo = "";
	$evento= 0;
      #  next if ( !zmShmVerify( $monitor ) );        IT GIVES ME ERROR... I DON'T KNOW WHY
	$evento= 1;
	$led = $monitor->{LED};
	$prima = substr($binario, 0, 8 - $led );
	$dopo = substr($binario, 8 - $led +1);
	$binario = $prima . "1" . $dopo;
		if ($evento == 1)
			#converts binary to decimal
			print( "binary " . $binario. " ->>  decimal ". $decimale . "\n" );
    sleep( 1 );
