New Skin for 1.24
kylejohnson
Post by kylejohnson » Fri Jun 04, 2010 6:23 pm
lookathome wrote:Hello here I'm!
If i set "Authenticate user logins to ZoneMinder (?)" i dont see camera preview in the console screen.
I've downloaded lastest version of the skin.
That is correct - it is a listed bug. When using ZM's built-in authentication, the you won't see camera snapshots. For the time being, I recommend using apache's mod_auth with a simple .htaccess file for authentication.
If someone would like to help me fix this bug, it would be very much appreciated!
Idling as gnulnx in #zoneminder on freenode. Come say hi!
kingofkya
Post by kingofkya » Fri Jun 04, 2010 9:12 pm
For otherbrowsers this may be of interest http://barelyfocused.net/blog/2008/10/0 ... is-player/
lookathome
Post by lookathome » Sun Jun 06, 2010 10:47 am
How about to make this more readeable ?
for example date and time on different lines ?
www.lookathome.it
IPCAM e Videosorveglianza
kylejohnson
Post by kylejohnson » Mon Jun 07, 2010 6:37 pm
lookathome wrote:How about to make this more readeable ?
Good idea. Done.
lookathome
Post by lookathome » Thu Jun 17, 2010 9:41 pm
when i export a video now is ogg format is this correct ?
and i cannot click on the video to watch it.
Also i cannot delete events (maybe becouse i have only one event?)
When no events the skin goes in infinite look.
When i cange option or delete a camera the skin does not refresh.
How about implement controls (i need to requery some time this :D ) ?
kylejohnson
Post by kylejohnson » Fri Jun 18, 2010 12:59 am
lookathome wrote:when i export a video now is ogg format is this correct ?
Now that you mention it, exporting a video is in .avi. However, viewing any event automatically generates a .ogg... I'll need to work on this. I went with .ogg as it is supported by Firefox.
And you're right - just the other day I noticed that there is no way to delete events. Again, something I will have to work on and implement.
Same with controls. :) Lots to do.
lookathome
Post by lookathome » Fri Jun 18, 2010 10:23 am
thanks a lot for your effort!
Really
www.lookathome.it
godsyn
Post by godsyn » Thu Jun 24, 2010 2:49 pm
I've graphed out the drive usage on system via css. Feel free to use.
Edit: code here seems to butcher css.
Link to pastebin: http://pastebin.org/356410
kp4djt
Post by kp4djt » Sun Jun 27, 2010 5:16 pm
I tried your work and after figuring out (and reading) that the directory must be named 'new'
I got it working, at least in parts. When I open it up a see a box for each camera, it appears
to try to pull the images in but then the boxes go down to a small size. I am trying to figure
this one out.
Inside each box is the name of the camera at the top and at the bottom "full view" Wonder
what I am doing wrong here?
Chuck Hast -- KP4DJT --
Web site www.wchast.com
ZM demo www.wchast.com/zm
roozbeh
Post by roozbeh » Wed Aug 18, 2010 6:18 pm
Very great work, thank you very much. I faced couple of issues:
* Authentication should be off
* skin folder name *should* be renamed to new
* language of server should be en_gb to view list of cameras
Very great user interface. Thank you
kylejohnson
Post by kylejohnson » Wed Aug 18, 2010 6:26 pm
roozbeh wrote:Very great work, thank you very much. I faced couple of issues:
There are a lot of issues with the skin as it stands :)
I just haven't had time to spend any serious amount of time to work on it. This is still an ongoing piece of work, so hopefully I'll get to address some of these issues soon!
DREMA
Post by DREMA » Wed Sep 01, 2010 12:33 pm
Any progress?
kylejohnson
Post by kylejohnson » Wed Sep 01, 2010 12:39 pm
DREMA wrote:Any progress?
Lots of progress, actually. Follow the 3 steps on the first post of this tread to checkout the skin (or just update it if you already have it). Then 'git checkout new-events', as that is where I have been doing the new work.
Skin is not 100% yet, but a lot of the features are coming to fruition. Please let me know what you think and REPORT BUGS! I have a very limited testing environment.
kylejohnson
Post by kylejohnson » Thu Sep 09, 2010 11:17 am
ANGUS509 wrote:I AM NEW HERE. GLAD TO SEE YOU ALL.
GLAD TO SEE YOU AS WELL.
Fixed a couple bugs in the latest commits. The events page should now display correctly in all resolutions.
logray
Post by logray » Sun Sep 12, 2010 4:59 pm
Wow! Stellar work here. Great job. :P
One thing I noticed is that the control feature does not work with this skin. View full, when I click control, the PTZ icons are not available. :-(
Other than that one "annoyance", this is amazing compared with the original skin !!!!
