Vivotek PTZ module
Normando
Vivotek PTZ module
Post by Normando »
Well, this is the vivotek module to control Vivotek PT7135 camera.
Name this file as "VivotekPT7135.pm" and copy under "control" perl modules.
# This module contains the implementation of the Vivotek PT7135 protocol
# It is easy to adapt to other Vivotek cameras. I have found a lot of commands with Wireshark
# This protocol get some info from the camera through receiveCmd function.
# Implement a pseudo diagonal movement
# Where go "presetClear" function from php code?
# Any improve is welcome, and please share it
# Normando Hall nhall[AT]unixlan[DOT]com[DOT]ar
package ZoneMinder::Control::VivotekPT7135;
use 5.006;
use strict;
use warnings;
require ZoneMinder::Base;
require ZoneMinder::Control;
# Vivotek PT7135 Control Protocol
use Time::HiRes qw( usleep );
sub new
    my $class = shift;
    my $id = shift;
    bless( $self, $class );
    srand( time() );
    return $self;
our $AUTOLOAD;
sub AUTOLOAD
    my $self = shift;
    my $name = $AUTOLOAD;
    $name =~ s/.*://;
    if ( exists($self->{$name}) )
        return( $self->{$name} );
sub open
    my $self = shift;
    $self->loadMonitor();
    use LWP::UserAgent;
    $self->{state} = 'open';
sub close
    my $self = shift;
    $self->{state} = 'closed';
sub printMsg
    my $self = shift;
    my $msg = shift;
    my $msg_len = length($msg);
sub sendCmd
    my $self = shift;
    my $cmd = shift;
    my $result = undef;
    printMsg( $cmd, "Tx" );
    #print( "http://$address/$cmd\n" );
    if ( $res->is_success )
        $result = !undef;
    else
    return( $result );
sub receiveCmd
    my $self = shift;
    my $cmd = shift;
    my $result = undef;
    printMsg( $cmd, "Rx" );
    my $content = $res->content();
        $result = $content;
    else
    return( $result );
sub reset
    my $self = shift;
    Debug( "Camera Reset" );
    my $cmd = "/cgi-bin/admin/setparam.cgi?System_Reset=3";
    $self->sendCmd( $cmd );
sub moveMap
    my $self = shift;
    my $params = shift;
    my $xcoord = $self->getParam( $params, 'xcoord' );
    my $ycoord = $self->getParam( $params, 'ycoord' );
    my $imagewidth = $self->{Monitor}->{Width};
    my $imageheight = $self->{Monitor}->{Height};
    Debug( "Move Map to $xcoord,$ycoord at $imagewidth/$imageheight" );
    if ( $imagewidth == "640" )
    $xcoord = $xcoord/2;
    $ycoord = $ycoord/2;
    my $cmd = "/cgi-bin/camctrl.cgi?cam1&x=$xcoord&y=$ycoord";
sub moveRelUp
    my $self = shift;
    my $params = shift;
    my $tiltspeed = $self->getParam( $params, 'tiltspeed' );
    Debug( "Move Up - Speed $tiltspeed" );
    my $cmd = "/cgi-bin/camctrl.cgi?move=up&speedtilt=$tiltspeed";
sub moveRelDown
    my $self = shift;
    my $params = shift;
    Debug( "Move Down - Speed $tiltspeed" );
    my $cmd = "/cgi-bin/camctrl.cgi?move=down&speedtilt=$tiltspeed";
sub moveRelLeft
    my $self = shift;
    my $params = shift;
    my $panspeed = $self->getParam( $params, 'panspeed' );
    Debug( "Move Left - Speed $panspeed" );
    my $cmd = "/cgi-bin/camctrl.cgi?move=left&speedpan=$panspeed";
sub moveRelRight
    my $self = shift;
    my $params = shift;
    Debug( "Move Right - Speed $panspeed" );
    my $cmd = "/cgi-bin/camctrl.cgi?move=right&speedpan=$panspeed";
sub moveRelUpRight
    my $self = shift;
    my $params = shift;
    Debug( "Move Up/Right - Speed $tiltspeed/$panspeed" );
sub moveRelUpLeft
    my $self = shift;
    my $params = shift;
    Debug( "Step Up/Left - Speed $tiltspeed/$panspeed" );
sub moveRelDownRight
    my $self = shift;
    my $params = shift;
    Debug( "Step Down/Right - Speed $tiltspeed/$panspeed" );
sub moveRelDownLeft
    my $self = shift;
    my $params = shift;
    Debug( "Step Down/Left - Speed $tiltspeed/$panspeed" );
sub whiteAuto
    my $self = shift;
    Debug( "White Auto" );
    my $cmd = "/cgi-bin/admin/setparam.cgi?Video_Whitebalance=0";
sub whiteMan
    my $self = shift;
    Debug( "White Man" );
    my $cmd = "/cgi-bin/admin/setparam.cgi?Video_Whitebalance=2";
sub In
    my $self = shift;
    Debug( "White In" );
    my $cmd = "/cgi-bin/admin/setparam.cgi?Video_Whitebalance=1";
sub Out
    my $self = shift;
    Debug( "White Out" );
    my $cmd = "/cgi-bin/admin/setparam.cgi?Video_Whitebalance=3";
sub presetClear
    my $self = shift;
    my $params = shift;
    my $preset = ( $preset - 1 );
    Debug( "Clear Preset $preset" );
    my $cmd = "/cgi-bin/admin/preset.cgi?delpos=$preset&Submit=Delete";
sub presetSet
    my $self = shift;
    my $params = shift;
    my $cmd = "/cgi-bin/admin/getparam.cgi?camctrl_axisx";
    my $rx = $self->receiveCmd( $cmd );
    my ($axisx) = $rx =~ /([-0-9]+)/;
    my $cmd = "/cgi-bin/admin/getparam.cgi?camctrl_axisy";
    my ($axisy) = $rx =~ /([-0-9]+)/;
    Debug( "Set Preset $preset at $axisx and $axisy" );
    my $cmd = "/cgi-bin/admin/setparam.cgi?camctrl_presetname_$preset=$preset&camctrl_presetpan_$preset=$axisx&camctrl_presettilt_$preset=$axisy";
sub presetGoto
    my $self = shift;
    my $params = shift;
    my $cmd = "/cgi-bin/recall.cgi?recall=$preset";
sub presetHome
    my $self = shift;
    Debug( "Home Preset" );
    my $cmd = "/cgi-bin/camctrl.cgi?move=home";
1;
__END__
Under control tab of your monitor:
Controllable: check
Control Device: none
Control Address: the camera IP, or user:pass@camera_ip
Return Location: Home
Leave other as default
Then click on "Edit" link at "Control Type" to create the new control module in the db.
At the new window click at the "Create New Control" button.
MAIN:
Type: Remote
Protocol: VivotekPT7135
Can Reset: Check
MOVE
Can Move: check
Can Move Diagonally: check
Can Move Mapped: check
Can Move Relative: check
PAN
Can Pan: check
Has Pan Speed: check
Min Pan Speed: -5
Max Pan Speed: 5
TILT
Can Tilt: check
Has Tilt Speed: check
Min Tilt Speed: -5
Max Tilt Speed: 5
WHITE
Can White Balance: check
Can Auto White Bal.: check
PRESETS
Has Presets: check
Num Presets: 20
Can Set Presets: check
Then, save and refresh you "Control Capabilities" window, and then close.
At your monitor window, refresh and selec from the pull-down list "Vivotek PT7135" at the "Control Type" field.
Save and enjoy
Normando
Post by Normando »
BTW: where go "presetClear" command? I have searched in the php files, and there is no exist. How to add this command/button?
Normando
Post by Normando »
Because Relative Diagonal Movements can't supply 'panspeed' or 'tiltspeed' parameter nor 'panstep' nor 'step' nor 'speed' (in don't know why), you sould modify the four relative diagonal functions to something like this. I give you an example for "moveRelUpRight":
sub moveRelUpRight
    my $self = shift;
    my $params = shift;
#    my $panspeed = $self->getParam( $params, 'panspeed' );
#    my $tiltspeed = $self->getParam( $params, 'tiltspeed' );
    my $panspeed = 0;
    my $tiltspeed = 0;
johnnytolengo
Post by johnnytolengo »
Thank for your effort , the script looks good. I have some questions.
Is it this camera a good choice?
I am looking arround cameras, this one is cheaper than other ones and looks good, my point is I don't want to buy something which will not work with zoneminder.
What about the image quality?
thank you in advance.
Compatriota tolengo desde Czech, gracias.
renemorenotx
SD7151 PTZ Zoneminder Control
Post by renemorenotx »
I Added the Control type like instructed on top. Where do I save the .pm file.
The only file I see is in /usr/bin zmcontrol.pl file. Do I edit this file?
A little new to zoneminder.
Notice: Undefined index: WhiteRoot in /usr/share/zoneminder/skins/classic/includes/control_functions.php on line 86
Notice: Undefined index: WhiteRoot in /usr/share/zoneminder/skins/classic/includes/control_functions.php on line 87
In
White
Out
Pan/Tilt- I get this when I hit control tab under source when I look at the video feed.
ilios
control module
Post by ilios »
does your module apply also to vivotek ptz7131?
http://www.vivotek.com/products/model.p ... era=pz7131
i have tied following your instruction butt no success...
can you please help to make the ptz control work on that camera?
thanksa lot!!
merlino63
Vivotek PZ7131.pm
Post by merlino63 »
This is .pm file for IP CAM Vivotek PZ7131
package ZoneMinder::Control::VivotekPT7131;
use 5.006;
use strict;
use warnings;
# Vivotek PZ7131 Control Protocol
sub new
my $class = shift;
my $id = shift;
srand( time() );
return $self;
our $AUTOLOAD;
sub AUTOLOAD
my $self = shift;
$name =~ s/.*://;
sub open
my $self = shift;
use LWP::UserAgent;
sub close
my $self = shift;
sub printMsg
my $self = shift;
my $msg = shift;
sub sendCmd
my $self = shift;
my $cmd = shift;
my $result = undef;
$result = !undef;
else
return( $result );
sub receiveCmd
my $self = shift;
my $cmd = shift;
my $result = undef;
$result = $content;
else
return( $result );
sub reset
my $self = shift;
my $cmd = "/cgi-bin/admin/setparam.cgi?reset=3";
sub moveMap
my $self = shift;
my $params = shift;
my $cmd = "/cgi-bin/viewer/camctrl.cgi?channel=0&cameraid=1&vx=$xcoord&vy=$ycoord&vs=3";
sub moveRelUp
my $self = shift;
my $params = shift;
my $cmd = "/cgi-bin/viewer/camctrl.cgi?move=up&tiltspeed=$tiltspeed";
sub moveRelDown
my $self = shift;
my $params = shift;
my $cmd = "/cgi-bin/viewer/camctrl.cgi?move=down&tiltspeed=$tiltspeed";
sub moveRelLeft
my $self = shift;
my $params = shift;
my $cmd = "/cgi-bin/viewer/camctrl.cgi?move=left&panspeed=$panspeed";
sub moveRelRight
my $self = shift;
my $params = shift;
my $cmd = "/cgi-bin/viewer/camctrl.cgi?move=right&panspeed=$panspeed";
sub moveRelUpRight
my $self = shift;
my $params = shift;
sub moveRelUpLeft
my $self = shift;
my $params = shift;
my $self = shift;
my $params = shift;
sub moveRelDownLeft
my $self = shift;
my $params = shift;
my $cmd = "/cgi-bin/viewer/camctrl.cgi?move=down&stiltspeed=$tiltspeed";
sub whiteAuto
my $self = shift;
my $cmd = "/cgi-bin/admin/setparam.cgi?whitebalance=auto";
sub whiteMan
my $self = shift;
my $cmd = "/cgi-bin/admin/setparam.cgi?whitebalance=2";
sub In
my $self = shift;
my $cmd = "/cgi-bin/admin/setparam.cgi?whitebalance=1";
sub Out
my $self = shift;
my $cmd = "/cgi-bin/admin/setparam.cgi?whitebalance=3";
sub presetClear
my $self = shift;
my $params = shift;
my $cmd = "/cgi-bin/operator/ePreset.cgi?channel=0&delpos=$preset&Submit=Delete";
sub presetSet
my $self = shift;
my $params = shift;
my $cmd = "/cgi-bin/admin/getparam.cgi?axisx";
my $cmd = "/cgi-bin/admin/getparam.cgi?axisy";
my $cmd = "/cgi-bin/operator/ePreset.cgi?preset_i'$preset=$preset'_name&preset_i'$preset=$axisx'_pos&preset_i'$preset=$axisy'_size";
sub presetGoto
my $self = shift;
my $params = shift;
my $cmd = "/cgi-bin/camctrl/eRecall.cgi?channel=0&Recall=$preset";
sub presetHome
my $self = shift;
my $cmd = "/cgi-bin/viewer/camctrl.cgi?move=home";
1;
__END__
Zoom parameter are not correct but i correct it fast
Bye
