1.23 and debian/ubuntu package
PeterHoward
Post by PeterHoward » Sun Jan 13, 2008 11:58 pm
For those of you who have been wondering where it is . . . I decided to wait for 1.23.1. Now that it's out zoneminder_1.23.1-1_i386.deb shouldn't be too far away :D
ktheking
Post by ktheking » Mon Jan 14, 2008 1:15 am
good idea ...
This can save you (and us) of lot of time ...
Lee Sharp
Post by Lee Sharp » Mon Jan 14, 2008 4:56 pm
Hip Hip, Hooray!!!! :) One question/request... We have found some real advantages to running on 64bit. Will you be making 64bit packages or are we stuck on the repos version. ;) Is there anything you need for 64bit support? Thanks again...
haus
Post by haus » Mon Jan 14, 2008 8:50 pm
Not to pressure you, but I'm thinking of holding my breath in anticipation. :)
Seriously, though...really excited here...
d0t101101
Post by d0t101101 » Tue Jan 15, 2008 6:06 pm
I'm also looking forward to seeing the Ubuntu package, thanks for maintaining it.
rDr4g0n
Post by rDr4g0n » Tue Jan 15, 2008 6:14 pm
im working on setting up a system and as a total linux noob, im sure ive fubard my current install pretty badly. cant wait for the new one :)
thanks!!
________
Com?te
________
Vapolution
PeterHoward
. . . delay till weekend
Post by PeterHoward » Tue Jan 15, 2008 11:43 pm
Unfortunately my "real" job has decided to demand a bit more time from me this week. So I won't be looking at it until the weekend. :-(
On the 64-bit question - I just need a 64-bit build environment. My server now has an Athlon 64 but it's still running 32-bit Ubuntu. However, the versions that appear in Debian unstable and Ubuntu universe should be being built for X86-64 as part of their release process.
Meanwhile, zoneminder_1.22.3-10_i386.deb has gone into Debian "testing" which means that 1.22.3, at least, should end up in the next Debian "stable" release.
Lee Sharp
Post by Lee Sharp » Wed Jan 16, 2008 3:51 pm
You know how to make a 64 bit boot easy, right?
sda1 swap
sda2 32bit \
sda3 \home
sda4 64bit \
sda4 can be just a couple of gig. Easy way to test what is really 64bit OK, and still have your regular desktop. Now get to it. ;) If you need anything give a shout. I really want it since Ubuntu takes too long to build updates, and 1.23 won't be in until hardy+1.
mrd
Post by mrd » Fri Jan 18, 2008 6:36 pm
Any chance the new package will have ffmpeg support built in?
Thanks again for your work on this!
MRD
PeterHoward
Post by PeterHoward » Sun Jan 20, 2008 12:20 am
[quote="mrd"]Any chance the new package will have ffmpeg support built in?/quote]
Not in the -1 package. My intent is to get ffmpeg back in and working. The effort of getting ffmpeg working will hopefully not be that much, but that's still more than just rolling the packaging forwards :-). Hopefully not too long after that there will be a version with ffmpeg.
PeterHoward
For those wondering
Post by PeterHoward » Sat Jan 26, 2008 12:32 am
If you're wondering why there still isn't a package for 1.23.1, I describe the problem (plus a bit of followup discussion) over in this thread: http://www.zoneminder.com/forums/viewto ... 9288#39288
PJH
PeterHoward
Progress . . . . slow, but progress
Post by PeterHoward » Fri Feb 01, 2008 11:10 pm
The missing perl library is now sitting in the package upload queue for Debian (thanks to the debian-perl-group). I've arrange that, once it gets accepted into Debian Unstable, it will get pulled across pretty quickly into Ubuntu Universe.
Then I can get back to packaging up 1.23.1
Flash_
Post by Flash_ » Sat Feb 02, 2008 8:21 am
Does this one fix the wee bug whereby the images/ events/ sounds/ etc directories are re-created by dpkg as hard directories, regardless of whether symlinked dirs already exist?
PeterHoward
Post by PeterHoward » Sun Feb 03, 2008 11:12 am
Flash_ wrote:Does this one fix the wee bug whereby the images/ events/ sounds/ etc directories are re-created by dpkg as hard directories, regardless of whether symlinked dirs already exist?
I was unaware of that behaviour . . . . if you can provide me with a bit more detail (e.g. clean install, upgrade, "before" and "after" directory structures) I'll look into it.
PJH
Flash_
Post by Flash_ » Mon Feb 04, 2008 7:04 am
I posted about it here; http://www.zoneminder.com/forums/viewtopic.php?t=10904
(Last two)
A fairly minor bug in itself, but lost me a load of footage before I noticed. (The joys of updating on fridays...)
Users browsing this forum: No registered users and 10 guests
