Google web signin integration - one sign to rule them all
Anything you want added or changed in future versions of ZoneMinder? Post here and there's a chance it will get in! Search to make sure it hasn't already been requested.
aelg305
Post by aelg305 »
I noticed another post that talks about the re-Captcha, however, this has to do with login in into zoneminder using the Google credentials.
I'm wondering if anybody has looked into integrating google sign in, from here: https://developers.google.com/identity/sign-in/web/
This basically uses the google user credentials to sign in users...if you are already signed into Google, Gmail, etc.... it would sign you into ZM seamlessly.
Here are the steps by steps I found, however, I have NOT implemented it or tested, so not sure if this would be feasible:
https://developers.google.com/identity/ ... le-project
