Page 1 of 1
Definable storage duration
Posted: Mon Oct 25, 2010 5:12 pm
by Stefanix
I need a feature to keep the HDs clean while guaranteeing to keep a certain time span available for review, lets say the last 14 days.
I know there is an option to purge older events if the HD becomes full. I find those settings a bit complicated and the approach in general wrong. If you want to keep as much as possible, this might be the solution.
But realistically its more important to define the time span needed to review events in the past. There are also data privacy laws which could require to keep recorded images for not too long.
An easy option to define the time span to keep would be good.
If this is already possible, I'd be happy to learn about it.
Thanks!
Posted: Tue Oct 26, 2010 6:03 am
by PacoLM
Try searching ´Purge when full´, you could adjust the percentage of hard disk.
Date cleaning
Posted: Fri Feb 18, 2011 10:28 am
by Fitch
I clicked on the event filter, chose purge when full and added the following:
Date, less than, -180 days (roughly six months)
You might want to add :
Date, Less than, -14 days
Re: Definable storage duration
Posted: Sun Sep 25, 2011 7:51 pm
by boelle
nice one... took me a while to discover it... but with data protection laws we need to be able to mask out public area's
just a black mask next to the green and red....
