Flash streaming with live cd
Support and queries relating to third party Live CDs and DVD, VM images and other packaged distributions
jameswilson
Post by jameswilson » Wed Oct 18, 2006 11:13 pm
After all the chat about flash movies id like to play with it on the live cd. But if i add swf and see any pointers
James Wilson
zoneminder
Site Admin
Post by zoneminder » Fri Oct 20, 2006 8:58 am
Is there more to this post that was missed off?
Phil
jameswilson
Post by jameswilson » Fri Oct 20, 2006 9:03 am
lol no but yeah
i have put swf as the streaming type in option but i dont get flash movies. I assume ffmpeg is missing a build option?
cheers
James Wilson
zoneminder
Site Admin
Post by zoneminder » Fri Oct 20, 2006 9:11 am
I don't think you need a special option when building ffmpeg. Anything in any of the logs?
Phil
jameswilson
Post by jameswilson » Fri Oct 20, 2006 9:24 am
oops basic forum error. no i havnt looked i turned it on and assumed as everything else worked, something was borked, leave it with me ill check
sorry all
James Wilson
mrd
Post by mrd » Wed Jan 31, 2007 3:49 pm
So does this work? How can I set it up? I only see options for mpeg and jpeg streaming on 1.22.3.
I need the idiots guide...
MRD
jameswilson
Post by jameswilson » Wed Jan 31, 2007 6:22 pm
change the streaming type under options from asf to swf, but only works on certain framerates. I havnt tested much but on my system that 2 fps its fine
James Wilson
mrd
Post by mrd » Fri Feb 02, 2007 6:59 pm
With swf/flash set up as described, where and how will events be stored on the server. Can you change it back if you want to?
Thanks!
MRD
cordel
Post by cordel » Fri Feb 02, 2007 7:46 pm
All events are stored as jpegs. Changing the streaming type does not change the storage method. It only affects the streaming ;)
mrd
Post by mrd » Sat Feb 10, 2007 1:05 pm
Thiis is working very well for me now except that the cycle view is still using java. Can anyone tell me what setting will correct this.
MRD
cordel
Post by cordel » Sat Feb 10, 2007 1:08 pm
I think it's under the web tab
mrd
Post by mrd » Tue Feb 13, 2007 6:13 pm
I've tried just about every option I can find and the cycle view still plays using cambozilla. I'm wondering if there is a reason for it not using flash? Prehaps because it uses the image as a link to the separate camera view?
MRD
cordel
Post by cordel » Tue Feb 13, 2007 6:16 pm
You need to switch form jpeg streaming to mpeg streaming so that the web interface will use ffmpeg.
mrd
Post by mrd » Tue Feb 13, 2007 6:28 pm
I have mpeg selected and both the regular camera views and montage view work using swf/flash but for some reason the cycle view only loads using cambozilla.
MRD
cordel
Post by cordel » Tue Feb 13, 2007 7:18 pm
Yep you would be correct, It has been programed to work that way, I'm not sure why.
I'll see what I can do.
Users browsing this forum: No registered users and 9 guests
