Zmdv_2006 Mandriva ZoneMinder installer CD
Support and queries relating to third party Live CDs and DVD, VM images and other packaged distributions
a123
ANPR Tutorial
Post by a123 »
You can get some ideas in www.anpr-tutorial.com from Quercus Technologies manofacturer. It explains about anpr equipments, anpr software and enpr engine. Also speak about all-in-One equipments, the new ANPR generation.
Also you can get ideas in www.quercus.biz, it is a manufacturer of ANPR (It is means Automatic number plate recognition or LPR license plate recognition).
Have a nice day
DaGeek wrote:
jameswilson wrote:ok ok my heart was bleeding lol im seeding now
:D
Yay...
now all i have 2 do is wait....
Thanx James...
As soon as i get this new version i can start working on my 2 new
ideas i have,
the 1st is ANPR, i think i can get this workin... I have had some succsess
with ZM and ANPR and am just waitin for some new hardware from eBay
and this New Ver of the CD and i will continue working on it,
I will post if i am succsessful...
The 2nd idea is to have a monitor mode camera change 2 a modect mode
@ a predefinded time and them back again...
so i could have it as 'Monitor' during the working day, and 'modect' after
hours...
(this one should b easy...)
jameswilson
Post by jameswilson »
Ross
Does the normal non live 2006 cd have a mysql check etc at boot, and do you advise one. I usually do one one a day as well as start up, but looking for opionion on this.
I noticed the lice cd does a check on boot
James Wilson
rdmelin
Post by rdmelin »
No the Zmdv_2006 is all Mandriva standard packages except for zm and a couple perl mods. The mysql check at startup is a hack I included on the livecd. You could just copy it over from from a livecd. I think its a good idea. That's why I did it :)
jameswilson
Thanks Ross. I will look at the livecd hack and see what you have done
James Wilson
jameswilson
Ross, i am trying to chnage this wonderful 2006 based non live cd
from a 2.6.12 based kenel to a 2.6.17
Reason is it doesnt detect the newer sata ports and strangly enough wont install to ide on this board either.
2007 installs fine to pata or sata
I have followed the instructions for remastering and have replaced the boot and main kernel.rpm with the 2.6.17 versions but i assume when it boots into the installer it used the boot.iso that is elsewhere and that is still based on a 2.6.12 so i cant install.
Im not as clever as me thinks!
So any pointers. I dont want to install another distro as i know the hassle it causes. Coreys ctus fails with my board too, but i assume the new live cd would work but wont do mdadm raid.
I prefer the way 2006 installs anyway but if i have to i could install a new live cd then move over to raid but ideally i want to run a complete raid 1 system
Cheers Ross
James
James Wilson
silver-dagger
seed iso please
Post by silver-dagger »
Can somebody seed the ZMDV ISO please. Myself and two others are trying to d/l it and we all have 94.6%.
Thank You.....
rsadanan
Post by rsadanan »
i had the same problem
Error 403
i installed allthe ssh utilities from the cd
then it worked
best of luck
