Zmdv_2006 Mandriva ZoneMinder installer CD
Support and queries relating to third party Live CDs and DVD, VM images and other packaged distributions
RhettNyeDotOrg
problem - errors on disk?
Post by RhettNyeDotOrg »
I'm anxious to get started here but the first time I tried to install on a freshly recycled old P2 350, My install failed with this in the Kernel log:
<3>Buffer I/O error on device hdc, logical block 314648
<4>hdc: media error (bad sector): status=0x51 { DriveReady SeekComplete Error }
<4>hdc: media error (bad sector): error=0x34 { AbortedCommand LastFailedSense=0x03}
<4>ide: failed opcode was: unkown
<4>Eend_request: I/O error, dev hdc, sector 1258596
repeated multipe times, eg for 12585(72,76,80)
This repeated a bunch of times, all very similar errors. My MD5 sum on the CD-ROM passed. I kind of think it's the CD-ROM that's toasting me. Can anyone confirm?
Rhett
http://www.rhettnye.org/wildlife
jameswilson
Post by jameswilson »
is hdc one of your hd partitions? as its either your cd or you hd thats had it
James Wilson
DaGeek
Seeders ?
Post by DaGeek »
Have been tring to get this torrent for 2 days now..
Are there any seeders out there ?
jameswilson
i turned my client off about 2 days ago as my windows machine chews electricity so i have it sleep now, but i can load it up till you have it just let me know if you have no luck
James Wilson
RhettNyeDotOrg
hdc
HDC is CD-ROM, yes.
I abandoned the Mandriva install disk and went straight to Debian. Debian installed on my machine OK, and I found a great forum post (yet another debian install how-to)
Now i just have to get the FAQ read and understood and I'll be ready to rock. Thanks anyways!
DaGeek
Post by DaGeek »
jameswilson wrote:i turned my client off about 2 days ago as my windows machine chews electricity so i have it sleep now, but i can load it up till you have it just let me know if you have no luck
Thx, Im now @ 98.7% and have been for a wile now...
i have quite a few www servers that i own, most are on a 10Mbps
or above internet connection, as soon as i get this ISO and as long
as i have the permission of rdmelin i will host it on 1 or more of my
servers and then post the URL of the file.
itz just that last tiny little bit that is stopping me :( ....
plz any1 i just need the smalles amount, just an hour or ur time
as a seed would do it, then i will seed the file, until the next version
is out, then i will seed that 1, and so on....
jameswilson
ok ok my heart was bleeding lol im seeding now
James Wilson
DaGeek
Post by DaGeek »
jameswilson wrote:ok ok my heart was bleeding lol im seeding now
:D
Yay...
now all i have 2 do is wait....
Thanx James...
As soon as i get this new version i can start working on my 2 new
ideas i have,
the 1st is ANPR, i think i can get this workin... I have had some succsess
with ZM and ANPR and am just waitin for some new hardware from eBay
and this New Ver of the CD and i will continue working on it,
I will post if i am succsessful...
The 2nd idea is to have a monitor mode camera change 2 a modect mode
@ a predefinded time and them back again...
so i could have it as 'Monitor' during the working day, and 'modect' after
hours...
(this one should b easy...)
zoneminder
Site Admin
Post by zoneminder »
The second idea is already possible by using 'run states' and a quick cron job or other script. I will be adding a scheduler function at some point ot make this easier.
I would be interested to see how you get on with ANPR, perhaps you could create a Wiki page to track your progress.
Phil
RedFlyer
Post by RedFlyer »
Hi Bosskong !
I get the same problem, and the problem was a missing module for PHP -> apache-mod_php. Just install it and this run perfectly !
Reboot your machine to be sure that everything is loaded correctly.
Regards,
Oliver
bosskong wrote:I just installed from this CD. When I open Firefox and go to "http://localhost/", I get:
It works!
But, when I go to "http://localhost/zm/", I get:
Access forbidden!
You don't have permission to access the requested directory. There is either no index document or the directory is read-protected.
If you think this is a server error, please contact the webmaster.
Error 403
localhost
Apache/2.0.54 (Mandriva Linux/PREFORK-13mdk)
Any ideas on what I need to do? The /var/www/html/zm directory has a bunch of zm files in it, but no index.html. It does have an index.php link that points to zm.php. Any ideas?
________
Toyota Vanguard
goatcatcher
Seeders?
Post by goatcatcher »
Any seeders out there for the torrent?
I can't seed afterwards but am happy to host the disk image for a while (depending on what demand turns out to be!).
rdmelin
Post by rdmelin »
OK I'm seeding again.
Be sure this is the one you want, there is a Mandriva 2006 based ZMliveCD_1.22.2 now also :)
jameswilson
I didnt stop seeding it? so im unsure why you couldnt get it from me
James Wilson
goatcatcher
Thanks guys, it's chugging along nicely now.
That's the one I'm downloading (I hope!) but couldn't find a thread for it on its own.
rdmelin - are you happy for me to host this somewhere and post the location back to the forum? I've got some bandwidth GBs that I'm not using to their full potential at the moment...
rdmelin
Post by rdmelin »
Replied by PM
Ross
