Page 1 of 1
Migrate from host zoneminder setup to docker keeping monitor zones
Posted: Tue Aug 27, 2019 6:06 am
by Adm746
I am slowly transferring my home server applications from the host machine to containers using docker-compose. While I have been able to get several versions of a zoneminder-in-docker up and running, I am unable to pull my old monitor zones from the host setup and import them into a docker setup.
I gather from other posts that the zone configurations are contained in the MySQL database, and simply copying the MySQL/zm folder will not suffice. Has anyone successfully migrated from a host setup to a docker setup maintaining your monitor zones? If so could you share the steps? MySQL commands etc.
Re: Migrate from host zoneminder setup to docker keeping monitor zones
Posted: Wed Aug 28, 2019 6:27 am
by Adm746
so for the QuantumObject\Docker the zones and monitors are stored in .ibd files under their respective names in /var/lib/mysql. Can I simply replace these files, or do I need to use mysql
Posted: Wed Aug 28, 2019 1:37 pm
by iconnor
use mysqdump to dump the db and import it into the new mysql server.
Or just import your nightly backup. You do have a nightly backup, right?
