Page 1 of 1
Low CPU usage
Posted: Fri Jun 01, 2018 8:51 pm
by apolonio
Was hoping to use an old laptop as a zoneminder NVR box. Looking at about 4 1080P streams via H.264 RTSP streams.
If I do not do any image analysis, (MONITOR, RECORD or NODECT) to CPU requirements drop or is there still a high CPU requirement due to the need to decode those streams?
The laptop is a Dell 6510 Core i5, 2.67Ghz, 4GB of RAM, and a 5400RPM 1TB drive. Gig ethernet.
Re: Low CPU usage
Posted: Sun Aug 05, 2018 1:47 am
by Lee Sharp
You will need to decode the h264 and then display it, so there is some work. And 1080p is not lightweight. I have 4 720 streams in a VM with 2 cores and 3 gig of ram and I am getting close to the limits when I am looking at video. This is with modetect however.
