Question: Bananian Debian ARMHF current version
Support and queries relating to third party Live CDs and DVD, VM images and other packaged distributions
Post by inoculator » Mon Apr 04, 2016 8:31 am
Hi all,
I was running Zoneminder 1.28 on a regular x86 machine with Ubuntu 12.04 32bit.
For powersaving reasons and because of the SATA Port I have switched to a Banana Pro.
During the install of the Bananian OS, which comes as Debian Jessie version, I figured out, that Zoneminder was not that far at that time and I had to go back to the older Wheezy Debian containing Zoneminder 1.25. It is running stable, but with the disadvantages of the older versions of course.
So much for the history.
Now I would like to know, how far we are right now?
I have seen 1.29.0 in the Jessie repositories for ARMHF. Has anybody got this combination running stable on a Banana Pro?
At the moment I have no spare Banana Pro, otherwise I would test it myself. But at the moment I would have to take my running ZM offline to have a reasonable test ;-)
Re: Question: Bananian Debian ARMHF current version
Post by sirAnton » Wed Oct 05, 2016 3:48 pm
Hello, i have tried to install zoneminder on 3.4.112-bananian bpi 1.
The error is:
  • Some packages could not be installed. This may mean that you have
    requested an impossible situation or if you are using the unstable
    distribution that some required packages have not yet been created
    or been moved out of Incoming.
    The following information may help to resolve the situation:
    The following packages have unmet dependencies:
    zoneminder : Depends: policykit-1 but it is not going to be installed
    E: Unable to correct problems, you have held broken packages.
Does any zoneminder version works with 3.4.112-bananian (debian jessie)?
