2x5Mpixel and 6x300Kpixel camera
Support and queries relating to third party Live CDs and DVD, VM images and other packaged distributions
fi2
Post by fi2 » Wed Oct 17, 2012 10:43 am
I need to install 2 x 5Mpixel (2592×1920) and 6x300Kpixel (640x480) cameras. I have only used Zoneminder with 640x480 ones before. I found the reference several places, that Zoneminder does not support event recording with any camera with higher resolution than VGA. Is it true? If so, is there a way to record the events in the higher, native resolution? Even if not the full blown 5Mpix, at least 2Mpix?
What machine specification can manage this load?
Thanks for any help,
Istvan
theforce
Re: 2x5Mpixel and 6x300Kpixel camera
Post by theforce » Fri Nov 16, 2012 10:43 pm
I've recently installed two 800x600 cameras. Not MP but higher than 640x480. They work just fine in modetc mode with multiple motion detection zones.
Dont know about machine specs. I'm running an AMD 4 core (I forget the speed) with two 500GB drives in raid 1. I have 14 cameras. 2x 800x600 and 12 640x480 with multiple motions zones each. Recording at 5fps. System load is around 4.0 or less on average. CPU is about 70-80%.
gerfry
Post by gerfry » Sat Nov 17, 2012 9:42 am
Hi fi2. Thanks for your contribution!
Which cameras do you use?
I'm using 10 Axis2100 (4 on motion, the rest just for viewing) on a Duron1,4Ghz with massive load (3-4). Unfortunately, that's definitely too weak hardware I guess...
Best
gerfry
riham
Post by riham » Sat Dec 06, 2014 4:43 am
Very Nice…
I like the distro' a lot…
One thing about the ZM installation I can't see it from outside the box, I can see it from the box, the web server does not server up to anyone outside the system….
Thanks...
Users browsing this forum: No registered users and 5 guests
