Hello all,
I did the following:
* Downloaded the virtual appliance.
* editted the vmx as discribed in article (edit vmx for serial usb and sound)
* Removed the png
Uploaded the data to the datastore and added the VM to the inventory.
When i then start the VM i get the errors as attached.
Does anyone knows what goes wrong? Seems like a problem with the ubuntu iso. Strangly enough it worked before a couple of weeks ago. I think the only different is that this host is patches with latest firware and drivers..
Hope someone can help me out here.
Zoneminder Virtual Appliance : Invalid virtual machine confi
- error2.jpg (57.91 KiB) Viewed 3822 times
- error1.jpg (31.63 KiB) Viewed 3822 times
Re: Zoneminder Virtual Appliance : Invalid virtual machine c
I removed some of the settings in the vmx which were not relevant such as the ubuntu disk. I now get another error, seems to be something wrong with the harddisk file. See the attachment.
Anyone idea's? Tried everything, such as creating a new virtual machine and adding the disk. Then also the error appears.
- error3.jpg (36.5 KiB) Viewed 3820 times
The issue is how the vmdk has been provisioned, if you look in your VM settings, rather than thin or thick provisioned it lists the disk provisioning as "sparse", which ESXi (and I suspect your version of VMWare) doesnt support.
To fix it you need to get to the command console / shell and use the following command to clone the vmdk into a useable format
vmkfstools -i "/vmfs/volumes/<Your Datastore Name>/zoneminder_va_0_2/Zoneminder.vmdk" -d thin "/vmfs/volumes/<Your Datastore Name>/zoneminder_va_0_2/ZoneminderThin.vmdk"
This will clone the vmdk as a thin provisioned disk, once you've done this remove the Zoneminder.vmdk from settings then attach the new ZoneminderThin.vmdk in it's place, and it should now boot.
