ZMlarch 2.24.2 - Events wont delete from Disk
Support and queries relating to third party Live CDs and DVD, VM images and other packaged distributions
TucsonDirect
Post by TucsonDirect »
Events wont delete from Hdd And when it fills up a nasty domino effect takes place.
Its like the zm audit isnt clearing the events from the harddrive, Disk fills up, Access is lost, Sql Crashes (too many connections) Then Db gets corrupt, Then Zm wont start, sql wont start. Then i cant delete the files because the disk is so full that the Auth(file thing) wont copy....
Has anyone else had this issue?
im using a 300 Gb hard drive, everything is on 1 partition except the boot partition
