ZMLARCH localhost not working.
Support and queries relating to third party Live CDs and DVD, VM images and other packaged distributions
giloosh
Post by giloosh »
I installed this Live cd http://www.isentrix.com/pub/zoneminder/ ... x/ZMLarch/
Network works, and internet works but I cannot get view the webserver.
I tried typing the following into firefox: http://localhost as well as http://127.0.0.1
What webserver is running anyway? I cannot find one under netstat
Please help.
parabolix
Post by parabolix »
I had this too.
in /etc/httpd/httpd.conf I added this line:
servername zmhost
then in /etc/hosts I added
127.0.0.1 localhost.localdomain localhost zmhost
which is similar to an existing line, but without the version number.
i left the existing line intact.
do a sudo httpd -k start and you should be up and running.
ashdavely
Post by ashdavely »
I also had this problem with the livecd and this resolved it for me. Apache worked fine when booting off the cd but not after installing to the hard disk.
jamest142
Post by jamest142 »
Hiya
Check the hosts file - remove the underscore and numbers from the end of the 127.0.0.1 line
Best regards
James
TucsonDirect
Re: ZMLARCH localhost not working.
Post by TucsonDirect »
:!: :!: SOME ONE SHOULD ADD THIS INFO TO THE WIKI :!: :!:
morch
Post by morch »
Does anyone still have the ZMLArch Live CD iso? If yes, would you be able to share with me please?
