Help with remote viewing
Support and queries relating to third party Live CDs and DVD, VM images and other packaged distributions
treesloth
Post by treesloth »
I am using ZMarch 1.24.1, tried searching through shaman package mananger and didn't see a dyndns updater. Is there another way to set it up. I saw elsewhere people use a programm called yoics. Any help would be much appreciated.
rdmelin
Post by rdmelin »
ddclient is already installed. All that is needed is to edit /etc/ddclient/ddclient.conf and then add ddclient to the DAEMONS=( ... ) line in /etc/rc.conf.
treesloth
Working fine
Post by treesloth »
I must have missed this somewhere, but I can't figure how to set up privelages for when people view my cameras over the web. Could someone point me int the right direction to get it more secure and prevent people from changing options.
rdmelin
Post by rdmelin »
You will first have to turn on authentication:
Option -> System -> OPT_USE_AUTH
Then you can configure users in the Options -> Users tab
This Tab doesn't appear in Options until you turn on auth.
dmravinac
Post by dmravinac »
rdmelin wrote:ddclient is already installed. All that is needed is to edit /etc/ddclient/ddclient.conf and then add ddclient to the DAEMONS=( ... ) line in /etc/rc.conf.
I have ArchLiveCD of Zoneminder and canot change ddclient.conf because must be loged as root (how?).
Next question, my router canot forward port 80. How I can shange Zoneminder server port?
jameswilson
Post by jameswilson »
you can chnage the apache port number from the apache conf file.
alternativly if your router supports it you can forward port say 82 to 80
James Wilson
dmravinac
Post by dmravinac »
Thanks.
Do you know where is this file and how to change port?
Next, I need fixed local address for server (no DHCP).
jameswilson
i dont know this distro but im assuming its in /etc/
re your ip add, is there not a settings panel on this thing?
James Wilson
dmravinac
Post by dmravinac »
I loged as root and try to find with mc any file with Apache settings but ... nope.
jameswilson
have you looked for apache.conf in /etc/
or httpd.conf?
James Wilson
dmravinac
Post by dmravinac »
O thank you.
Is httpd.conf
