problem initiating Zoneminder in OpenSuse
Just installed Zoneminder (Opensuse 10.2), using Yast. The install completed successfully. I opened root consol and followed the instructions. When I type in zm_database_init, a message displays “no lockfile found”, then alerts me that daemon failed. This is my first time with Linux, so please be gentle…
You will have to contact the packager, since we do not package for suse, I have no way to know what they have done and we do not provide a database init program. I would suggest installing from source or if you can figure out what they have done from the code, try manually installing the database. They should have contact info somewhere in that package so that you can get help. I can't remember off the top off my head if it's anyone that frequents the forum.
it seems that you already run zm_databaes_init. maybe you did not answer all questions with "yes", so lets do it again
first thing you could do is run zm_database_init and when "no lockfile found, proceed anyway? [y/N]: " is display answer with "y". and then follow the instructions in the wiki.
when this not works, then try to run zmpkg start and post the output here.
hope this helps
hope this helps
linux-rine:~ # zmpkg.pl start
linux-rine:~ # zmpkg.pl stop
linux-rine:~ # sh -x /etc/init.d/zm start
+ ZM_BIN=/usr/bin/zmpkg.pl
+ ZM_PATH=/srv/www/htdocs/zm
+ test -x /usr/bin/zmpkg.pl
+ . /etc/rc.status
++ LC_ALL=POSIX
++ export LC_ALL
++ test -z '' -o -z ''
+++ exec
+++ stty size
+++ read L C
+++ echo LINES=24 COLUMNS=80
++ eval LINES=24 COLUMNS=80
+++ LINES=24
+++ COLUMNS=80
++ test 24 -eq 0
++ test 80 -eq 0
++ export LINES COLUMNS
++ case ":$PATH:" in
++ test -t 1 -a xterm '!=' raw -a xterm '!=' dumb
++ stty size
+++ echo -en '\033'
++ esc=$'\E'
++ extd=''
++ warn=''
++ done=''
++ attn=''
+++ echo -en '\017'
++ norm=''
+++ echo -en '\015 '
++ stat=' '
++ rc_done=' done'
++ rc_running=' running'
++ rc_failed=' failed'
++ rc_missed=' missing'
++ rc_skipped=' skipped'
++ rc_dead=' dead'
++ rc_unused=' unused'
++ rc_unknown=' failed''
++ rc_reset=''p='
++ rc_save=''
++ rc_restor'='
++ _rc_service=/etc/init.d/zm
++ _rc_status=0
++ _rc_status_all=0
++ _rc_todo=start
++ test start = status
++ test -n start
+ rc_reset
+ _rc_status=0
+ _rc_status_all=0
+ rc_check
+ _rc_status_ret=0
+ test 0 -eq 0
+ test 0 -eq 0
+ return
+ return 0
+ case "$1" in
+ locked=0
+ test -f /srv/www/htdocs/zm/lock
+ echo -n 'Starting ZoneMinder Daemon '
Starting ZoneMinder Daemon + (( 0 != 1 ))
+ eval startproc -t 5 -f /usr/bin/zmpkg.pl start
+ rc_status -v
+ rc_check
+ _rc_status_ret=0
+ test 0 -eq 0
+ test 0 -eq 0
+ return
+ test 0 -gt 7
+ _rc_status_ret=0
+ case "$_rc_todo" in
+ local i
+ for i in '"$@"'
+ case "$i" in
+ local vrt=
+ local out=1
+ local opt=en
+ test -n ''
+ opt=e
+ case "$_rc_status" in
+ vrt=' done'
+ echo -e '' done
done
+ _rc_status=0
+ return 0
+ rc_exit
+ exit 0
linux-rine:~ #
+ . /etc/rc.status
++ LC_ALL=POSIX
++ export LC_ALL
+++ exec
+++ stty size
+++ read L C
+++ LINES=24
+++ COLUMNS=80
++ test 24 -eq 0
++ test 80 -eq 0
++ stty size
+++ echo -en '\033'
++ esc=$'\E'
++ extd=''
++ warn=''
++ done=''
++ attn=''
+++ echo -en '\017'
++ norm=''
++ stat=' '
++ rc_done=' done'
++ rc_dead=' dead'
++ rc_reset=''p='
++ rc_save=''
++ rc_restor'='
++ _rc_status=0
++ _rc_status_all=0
++ _rc_todo=start
++ test -n start
+ rc_reset
+ _rc_status=0
+ _rc_status_all=0
+ rc_check
+ _rc_status_ret=0
+ test 0 -eq 0
+ test 0 -eq 0
+ return
+ return 0
+ case "$1" in
+ locked=0
+ rc_status -v
+ rc_check
+ _rc_status_ret=0
+ test 0 -eq 0
+ test 0 -eq 0
+ return
+ test 0 -gt 7
+ _rc_status_ret=0
+ local i
+ for i in '"$@"'
+ case "$i" in
+ local vrt=
+ local out=1
+ local opt=en
+ test -n ''
+ opt=e
+ vrt=' done'
+ echo -e '' done
done
+ _rc_status=0
+ return 0
+ rc_exit
+ exit 0
linux-rine:~ #
ok also seems to be fine.
i don't know were the problem was, but alls seems to function now.
the start fails because zoneminder is already running.
as a final test you can run "rczm stop" to stop zoneminder then "rczm status" (must now be unused) then "rczm start" and "rczm status" (now running).
when no problems occur then all is fine \o/
you can acces zoneminder via http://localhost/zm with a browser from the same pc or from a an other computer than localhost via http://<hostip>/zm. before you can acces zm from an other box than localhost you have to open the port 80 in the firewall settings. to do so go to yast -> users and security -> firewall. select allowed services and choose "http-server" and click add.
to start zoneminder on boot type "chkconfig zm on"
hope this helps.
hope this helps.
Thanks for the help!
I guess when I tried to use the access link before, zm may not of been running.
Only problem know is the lack of active camera action.The montage link with which to view the cameras is missing. I know the camera and card is active as I rebooted my system into xp-pro and proved the camera is on and working.
Below is what I have displaying in my browser, after setting up 8 cameras which should cover all inputs into one of two connectors I have:
Fri 3rd Aug, 3:44pm ZoneMinder Console - Running - v1.22.3 Load: 1.97 / Disk: 49%
8 Monitors
Configured for low bandwidth
Options
Id Name Function Source Events Hour Day Week Month Archive Zones Order Mark
1. New None /dev/video (1) 0 0 0 0 0 0 1
2. New None /dev/video (2) 0 0 0 0 0 0 1
3. New None /dev/video (3) 0 0 0 0 0 0 1
4. New None /dev/video (4) 0 0 0 0 0 0 1
5. New None /dev/video (5) 0 0 0 0 0 0 1
6. New None /dev/video (6) 0 0 0 0 0 0 1
7. New None /dev/video (7) 0 0 0 0 0 0 1
8. New None /dev/video (8) 0 0 0 0 0 0 1
0 0 0 0 0 0 8
8 Monitors
Options
0 0 0 0 0 0 8
this could have many reasons.
you should check the system log files. first check /var/log/messages (use this command: "tail -f /var/log/messages" as root) there you might see some error messages which will help to analyse your problem. maybe you then can find a solution for your problem in the FAQ section. when you cannot find any errors in /var/log/messages you should look at the apache2 error logfile in /var/log/apache2/error_log.
hope this helps.
hope this helps.
Users browsing this forum: No registered users and 7 guests
