could not connect to database sql error,
TimboUK
Post by TimboUK » Sat Jul 28, 2007 2:29 pm
Help!
Been away for 2 weeks and now i tried to login (latest version) and all I get is the browser window saying cannot connect to the sql server....
Any idea whats happened. I dont want to have to reinstall everything again!
BTW total linux noob too; sorry!
I thought my disc may have filled up, but its listed as a 59gig, using 52gig. So theres free space there. Now I am at a loss!
TimboUK
Re: could not connect to database sql error,
Post by TimboUK » Sat Jul 28, 2007 5:38 pm
TimboUK wrote:Help!
Forgot to add the full error message:
Could not connect to database: Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (2)
Has anyone any suggestions please, I am totally stuck.
cordel
Post by cordel » Sat Jul 28, 2007 7:28 pm
Have you checked the logs, more specifically the mysql and messages log to see why it might have stopped?
TimboUK
Post by TimboUK » Sun Jul 29, 2007 1:53 pm
cordel wrote:Have you checked the logs, more specifically the mysql and messages log to see why it might have stopped?
sorry cordel, I am not sure where to look. I have looked in the FAQ and cannot find this error.
Lee Sharp
Post by Lee Sharp » Sun Jul 29, 2007 7:02 pm
post the output of this command.
sudo /etc/init.d/mysql restart
TimboUK
Post by TimboUK » Mon Jul 30, 2007 6:57 am
[guest ~]$ sudo /etc/init.d/mysql restart
sudo: /etc/init.d/mysql: command not found
[guest ~]$
Does that mean the SQL database is not running?
Lee Sharp
Post by Lee Sharp » Mon Jul 30, 2007 5:32 pm
That is the base script to start mysql. The run level directories have links to that script to start mysql, so if it is missing... Check the path to be sure. That is the path for Ubuntu and other debian based distributions. If the path is right, and the startup script is missing, I think we found your problem.
Users browsing this forum: No registered users and 21 guests
